Sensitivity of the Solution Set to Second Order Evolution Inclusions
In this note we study second order evolution inclusions in the framework of evolution triple of spaces. The existence of mild solutions (i.e. trajectory-selection pairs) to the inclusion, and the upper and lower semicontinuity properties of the solution set with respect to a parameter are established.
