Optimal control of variational inequalities, Research Notes in Mathematics, vol.100, 1984. ,
A LEVEL SET BASED SHAPE OPTIMIZATION METHOD FOR AN ELLIPTIC OBSTACLE PROBLEM, Mathematical Models and Methods in Applied Sciences, vol.21, issue.04, pp.619-649, 2011. ,
DOI : 10.1142/S0218202511005155
Probì emes unilatéraux, J. Math. Pures Appl, vol.51, issue.9, pp.1-168, 1972. ,
Les inéquations en mécanique et en physique, Travaux et Recherches Mathématiques, issue.21, 1972. ,
Weak and variational methods for moving boundary problems, Research Notes in Mathematics, vol.59, 1982. ,
Numerical analysis of variational inequalities, Studies in Mathematics and its Applications, 1981. ,
Existence and approximation for a steady fluid-structure interaction problem using fictitious domain approach with penalization, Mathematics and its Applications, vol.5, issue.12, pp.120-147, 2013. ,
Path-following Methods for a Class of Constrained Minimization Problems in Function Space, SIAM Journal on Optimization, vol.17, issue.1, pp.159-187, 2006. ,
DOI : 10.1137/040611598
A mesh-independence result for semismooth Newton methods, Math. Program., Ser. B, vol.101, pp.151-184, 2004. ,
Adaptive Multilevel Methods for Obstacle Problems, SIAM Journal on Numerical Analysis, vol.31, issue.2, pp.301-323, 1994. ,
DOI : 10.1137/0731016
Semi???Smooth Newton Methods for Variational Inequalities of the First Kind, ESAIM: Mathematical Modelling and Numerical Analysis, vol.37, issue.1, pp.41-62, 2003. ,
DOI : 10.1051/m2an:2003021
Augmented Lagrangian Active Set Methods for Obstacle Problems, Journal of Optimization Theory and Applications, vol.55, issue.3, pp.499-533, 2003. ,
DOI : 10.1023/B:JOTA.0000006687.57272.b6
An introduction to variational inequalities and their applications. Reprint of the 1980 original, Classics in Applied Mathematics, vol.31, p.SIAM, 2000. ,
A duality algorithm for the obstacle problem, Annals of the Academy of Romanian Scientists, vol.5, issue.12, pp.209-215, 2013. ,
A duality-type method for the fourth order obstacle problem, U.P.B. Sci. Bull., Series A, vol.76, issue.2, pp.147-158, 2014. ,
A direct algorithm in some free boundary problems, submitted to, Journal of Numerical Mathematics, 2014. ,
Fixed domain approaches in shape optimization problems with Dirichlet boundary conditions, Inverse Problems, vol.25, issue.5, pp.1-18, 2009. ,
DOI : 10.1088/0266-5611/25/5/055003
Optimization of elliptic systems. Theory and applications, 2006. ,
Optimal Control of Nonlinear Parabolic Systems. Theory , Algorithms, and Applications, Monographs and Textbooks in Pure and Applied Mathematics, 1994. ,
Fixed domain approaches in shape optimization problems, Inverse Problems, vol.28, issue.9, pp.1-35, 2012. ,
DOI : 10.1088/0266-5611/28/9/093001
Obstacle Problems in Mathematical Physics, 1987. ,
Optimal Control of Nonsmooth Distributed Parameter Systems, 1990. ,
DOI : 10.1007/BFb0085564
An algorithm for solving the obstacle problems, Computers & Mathematics with Applications, vol.48, issue.10-11, pp.10-11, 2004. ,
DOI : 10.1016/j.camwa.2004.02.007
An algorithm for solving the double obstacle problems, Applied Mathematics and Computation, vol.201, issue.1-2, pp.221-228, 2008. ,
DOI : 10.1016/j.amc.2007.12.015
