Optimum Experimental Designs, with SAS, 2007. ,
Estimation Techniques for Distributed Parameter Systems, 1989. ,
DOI : 10.1007/978-1-4612-3700-6
Optimal experiment design for open and closed-loop system identification, Communications In Information and Systems, vol.11, issue.3, pp.197-224, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00765659
Identification for Control: From the Early Achievements to the Revival of Experiment Design, European Journal of Control, vol.11, pp.1-18, 2005. ,
Dynamic System Identification. Experiment Design and Data Analysis, Mathematics in Science and Engineering, 1977. ,
For model-based control design, closed-loop identification gives better performance, Automatica, vol.32, issue.12, pp.1659-1673, 1996. ,
DOI : 10.1016/S0005-1098(96)80003-3
System Identification of Complex and Structured Systems, European Journal of Control, vol.15, issue.3-4, p.275310, 2009. ,
DOI : 10.3166/ejc.15.275-310
Closed loop experiment design for linear time invariant dynamical systems via LMIs, Automatica, vol.44, issue.3, p.623636, 2008. ,
DOI : 10.1016/j.automatica.2007.06.022
Optimal input signals for parameter estimation in dynamic systems--Survey and new results, IEEE Transactions on Automatic Control, vol.19, issue.6, 1976. ,
DOI : 10.1109/TAC.1974.1100701
Optimal sensor network scheduling in identification of distributed parameter systems, Lecture Notes in Control and Information Sciences, vol.425, 2012. ,
DOI : 10.1007/978-3-642-28230-0
Design of Experiments in Nonlinear Models, Lecture Notes in Statistics, vol.212, p.2013 ,
DOI : 10.1007/978-1-4614-6363-4
URL : https://hal.archives-ouvertes.fr/hal-00879984
A variational approach to optimal input signals for parameter estimation in systems with spatio-temporal dynamics, Proceedings of the 10th Int Workshop in Model-Oriented Design and Analysis, Lagow Series " Contribution to Statistics, pp.219-227, 2013. ,
Control of linear extended nD sytems with minimized sensitivity to parameter uncertainties, Multidimensional Systems and Signal Proc, pp.637-656, 2013. ,
Sampling multidimensional signals by a new class of quasi-random sequences, Multidim. Syst. Sign. Process, 2010. ,
Optimal Measurement Methods for Distributed Parameter System Identification, 2005. ,
DOI : 10.1201/9780203026786
Optimal input design for nonlinear dynamic systems: a graph theory approach, arXiv preprint arXiv:1310, 2013. ,
On the Performance of Optimal Input Signals for Frequency Response Estimation, IEEE Transactions on Automatic Control, vol.57, issue.3, pp.766-771, 2012. ,
DOI : 10.1109/TAC.2011.2166322
Optimal experimental design for dynamic system identification, Lecture Notes in Control and Information Science, vol.21, 1979. ,
