Accuracy and Convergence Properties of the Finite Difference Multigrid Solution of an Optimal Control Optimality System, SIAM Journal on Control and Optimization, vol.41, issue.5, pp.1477-1497, 2003. ,
DOI : 10.1137/S0363012901393432
Multigrid methods for parameter dependent problems, ESAIM: Mathematical Modelling and Numerical Analysis, vol.30, issue.3, pp.265-297, 1996. ,
DOI : 10.1051/m2an/1996300302651
Multi-Grid Methods and Applications, 1985. ,
DOI : 10.1007/978-3-662-02427-0
Preconditioned Conjugate Gradient Method for Optimal Control Problems with Control and State Constraints, SIAM Journal on Matrix Analysis and Applications, vol.31, issue.5, pp.2291-2317, 2010. ,
DOI : 10.1137/090779127
A Robust Multigrid Method for Elliptic Optimal Control Problems, SIAM Journal on Numerical Analysis, vol.49, issue.4, pp.1482-1503, 2011. ,
DOI : 10.1137/100783285
A robust all-at-once multigrid method for the Stokes control problem, Numerische Mathematik, vol.32, issue.3, 2013. ,
DOI : 10.1007/s00211-014-0674-5
Convergence Analysis of Multigrid Methods with Collective Point Smoothers for Optimal Control Problems, Computing and Visualization in Convergence analysis of all-at-once multigrid methods for elliptic control problems under partial elliptic regularity, Science SIAM Journal on Numerical Analysis, vol.14, issue.51 3, pp.131-141, 2011. ,
Block-implicit multigrid solution of Navier-Stokes equations in primitive variables, Journal of Computational Physics, vol.65, issue.1, pp.138-158, 1986. ,
DOI : 10.1016/0021-9991(86)90008-2
Nonstandard Norms and Robust Estimates for Saddle Point Problems, SIAM Journal on Matrix Analysis and Applications, vol.32, issue.2, pp.536-560, 2011. ,
DOI : 10.1137/100814767
