A Numerical Approach to the Optimal Control and Efficiency of the Copepod Swimmer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This article presents a geometric and numericalapproach to compute the optimal swimming strokes of a larvalcopepod. A simplified model of locomotion at low Reynoldsnumber is analyzed in the framework of Sub-Riemanniangeometry. Both normal and abnormal geodesics are consideredalong which the mechanical power dissipated by the swimmeris conserved. Numerical simulations show that, among variousperiodic strokes, a normal stroke consisting of a simple loopshape is maximizing the efficiency.
Copepod-CDC.pdf (999.91 Ko) Télécharger le fichier
hal-01286602 , version 1 (11-03-2016)
hal-01286602 , version 2 (04-04-2016)
hal-01286602 , version 3 (24-10-2016)
Bernard Bonnard, Monique Chyba, Jérémy Rouot, Daisuke Takagi. A Numerical Approach to the Optimal Control and Efficiency of the Copepod Swimmer. 55th IEEE Conference on Decision and Control - CDC, Dec 2016, Las Vegas, United States. pp.4196-4201, ⟨10.1109/CDC.2016.7798906⟩. ⟨hal-01286602v3⟩
343 Consultations
313 Téléchargements
