Boulakhras Gherbal Efficient Solvers for Large-Scale Saddle Point Systems Arising in Feedback Stabilization of Multi-field Flow Problems, p.11 ,
Weichelt Stochastic Control of Econometric Models for ,
Neck The Optimal Control of Cellular Communication Enterprise Development in Competitive, p.31 ,
Ogurtsova Simulation of Acoustic Wave Propagation in Anisotropic Media Using Dynamic Programming Technique, p.36 ,
Vicente Two Semi-Lagrangian Fast Methods for Hamilton-Jacobi-Bellman Equations, p.74 ,
and Maurizio Falcone Dynamic Sampling Schemes for Optimal Noise Learning Under Multiple Nonsmooth Constraints, p.85 ,
Bibiane Schönlieb Exponential Convergence to Equilibrium for Nonlinear Reaction-Diffusion Systems Arising in Reversible Chemistry, p.96 ,
Impulse Control of Standard Brownian Motion: Long-Term Average Criterion, p.148 ,
Stockbridge, and Chao Zhu Impulse Control of Standard Brownian Motion: Discounted Criterion, p.158 ,
Zhu On Target Control Synthesis Under Set-Membership Uncertainties Using Polyhedral Techniques, 170 Elena K. Kostousova Application of the Fenchel Theorem to the Obstacle Problem . . . . . . . . . . . . 181 Diana R. Merlu?c? ,
Vrabie Graphical Lasso Granger Method with 2-Levels-Thresholding for Recovering Causality Networks, p.220 ,
Right-Hand Side Dependent Bounds for GMRES Applied to Ill-Posed Problems ,
and Martin Horn Regularization of Linear-Quadratic Control Problems with L 1 -Control Cost, p.296 ,
Alt Deployment of Sensors According to Quasi-Random and Well Distributed Sequences for Nonparametric Estimation of Spatial Means of Random Fields, p.306 ,
337 Stefan Takacs Continuous-Time Local Model Network for the Boost-Pressure Dynamics of a, -Hinrik Höper, and Romain Hurtado Erratum to: More Safe Optimal Input Signals for Parameter Estimation of Linear Systems Described by ODE . . . . . . . . . . . . . . . . . . . . . . . . . . . E1 Ewaryst Rafaj?owicz and Wojciech Rafaj?owicz ,
