Crack detection by the topological gradient method, Control and Cybernetics, vol.34, issue.1, pp.119-138, 2005. ,
The topological asymptotic for the Helmoltz equation, SIAM J. Control Optim, vol.42, issue.5, pp.1523-1544, 2003. ,
Mathematical Problems in Image Processing, Applied Mathematical Sciences, vol.147, 2001. ,
Image restoration and classification by topological asymptotic expansion, Variational Formulations in Mechanics: Theory and Applications, pp.23-42, 2007. ,
A topological asymptotic analysis for the regularized gray-level image classification problem, Math. Model. Numer. Anal, vol.41, pp.605-625, 2007. ,
Image processing by topological asymptotic expansion, J. Math. Imaging Vis, vol.33, pp.122-134, 2009. ,
O(N 2 log2N ) filtered backprojection reconstruction algorithm for tomography, IEEE Trans. Image Proc, vol.9, issue.10, pp.1760-1773, 2000. ,
Total variation image restoration: numerical methods and extensions, Proc. Int. Conf. on Image Processing, pp.384-387, 1997. ,
High order total variation based image restoration, SIAM J. Sci. Comput, vol.22, issue.2, pp.503-516, 2000. ,
The topological asymptotic for PDE systems: the elasticity case, SIAM J. Control Optim, vol.39, pp.17-49, 2001. ,
The topological asymptotic expansion for the Quasi-Stokes problem, ESAIM: Control Optim. Calc. Var, vol.10, pp.478-504, 2004. ,
Application of the topological gradient to image restoration and edge detection, Engineering Analysis with Boundary Elements, vol.32, issue.11, pp.891-899, 2008. ,
DOI : 10.1016/j.enganabound.2008.01.004
Nonlinear Total Variation based noise removal algorithms, Physica D, vol.60, pp.259-268, 1992. ,
Topological derivatives of shape functionals for elasticity systems, Int. Ser. Numer. Math, vol.139, pp.231-244, 2002. ,
