A sub-pixel resolution enhancement model for multiple-resolution multispectral images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a new resolution enhancement model, with application to MODIS and Sentinel-2 data. For applications like land cover monitoring, the availability of multispectral bands at multiple resolutions limits the classification accuracy at full resolution. We introduce a new model to separate pixel content from color information at high-resolution bands. This sub-pixellic model is then applied to unmix low-resolution bands. This technique drastically improves the overall land cover classification accuracy, especially in the MODIS cases, and it is particularly effective on Sentinel-2 data.
presentation_superres_egu.pdf (3.43 Mo) Télécharger le fichier
EGU2016-14389.pdf (31.04 Ko) Télécharger le fichier
hal-01287184 , version 1 (25-08-2016)
  • HAL Id : hal-01287184 , version 1
Nicolas Brodu, Dharmendra Singh, Akanksha Garg. A sub-pixel resolution enhancement model for multiple-resolution multispectral images. European Geophysical Union General Assembly 2016, Apr 2016, Vienne, Austria. ⟨hal-01287184⟩
Collections
INRIA INRIA2
101 Consultations
163 Téléchargements
