Scalable and Accurate Causality Tracking for Eventually Consistent Stores - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In cloud computing environments, data storage systems often rely on optimistic replication to provide good performance and availability even in the presence of failures or network partitions. In this scenario, it is important to be able to accurately and efficiently identify updates executed concurrently. Current approaches to causality tracking in optimistic replication have problems with concurrent updates: they either (1) do not scale, as they require replicas to maintain information that grows linearly with the number of writes or unique clients; (2) lose information about causality, either by removing entries from client-id based version vectors or using server-id based version vectors, which cause false conflicts. We propose a new logical clock mechanism and a logical clock framework that together support a traditional key-value store API, while capturing causality in an accurate and scalable way, avoiding false conflicts. It maintains concise information per data replica, only linear on the number of replica servers, and allows data replicas to be compared and merged linear with the number of replica servers and versions.
326177_1_En_6_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01287733 , version 1 (14-03-2016)
Paternité
Paulo Sérgio Almeida, Carlos Baquero, Ricardo Gonçalves, Nuno Preguiça, Victor Fonte. Scalable and Accurate Causality Tracking for Eventually Consistent Stores. 4th International Conference on Distributed Applications and Interoperable Systems (DAIS), Jun 2014, Berlin, Germany. pp.67-81, ⟨10.1007/978-3-662-43352-2_6⟩. ⟨hal-01287733⟩
111 Consultations
395 Téléchargements
