The design of the borealis stream processing engine, p.5, 2005. ,
COLR-Tree: Communication-Efficient Spatio-Temporal Indexing for a Sensor Data Web Portal, 2008 IEEE 24th International Conference on Data Engineering, pp.784-793, 2008. ,
DOI : 10.1109/ICDE.2008.4497487
Data Management in the Worldwide Sensor Web, IEEE Pervasive Computing, vol.6, issue.2, pp.30-40, 2007. ,
DOI : 10.1109/MPRV.2007.27
Efficient support for multi-resolution queries in global sensor networks, Proceedings of the 5th International Conference on Communication System Software and Middleware, COMSWARE '11, pp.1-11, 2011. ,
DOI : 10.1145/2016551.2016562
Distributed processing of very large datasets with DataCutter, Parallel Computing, vol.27, issue.11, pp.1457-1478, 2001. ,
DOI : 10.1016/S0167-8191(01)00099-0
Euro-Par '07, chap. Content-Based Publish/Subscribe Using Distributed R-Trees, pp.537-548, 2007. ,
Dynamic grid-based multicast group assignment in data distribution management, Proceedings Fourth IEEE International Workshop on Distributed Simulation and Real-Time Applications (DS-RT 2000), pp.47-54, 2000. ,
DOI : 10.1109/DISRTA.2000.874063
The steiner problem in graphs, Networks, vol.1, issue.3, pp.195-207, 1971. ,
DOI : 10.1002/net.3230010302
The many faces of publish/subscribe, ACM Computing Surveys, vol.35, issue.2, pp.114-131, 2003. ,
DOI : 10.1145/857076.857078
Realistic simulation environments for IP-based networks, Proceedings of the First International ICST Conference on Simulation Tools and Techniques for Communications Networks and Systems, pp.1-83, 2008. ,
DOI : 10.4108/ICST.SIMUTOOLS2008.3079
IrisNet: An architecture for a worldwide sensor web, IEEE Pervasive Computing, vol.2, issue.4, pp.22-33, 2003. ,
DOI : 10.1109/MPRV.2003.1251166
CeNSE: A central nervous system for the earth, 2011 IEEE Technology Time Machine Symposium on Technologies Beyond 2020, pp.1-1, 2011. ,
DOI : 10.1109/TTM.2011.6005162
Using Area Hierarchy for Multi-Resolution Storage and Search in Large Wireless Sensor Networks, 2009 IEEE International Conference on Communications, pp.1-6, 2009. ,
DOI : 10.1109/ICC.2009.5199556
Parametric Subscriptions for Content-Based Publish/Subscribe Networks, Middleware '10, pp.128-147, 2010. ,
DOI : 10.1007/978-3-642-16955-7_7
URL : https://hal.archives-ouvertes.fr/hal-01055268
A survey on the design, applications, and enhancements of application-layer overlay networks, ACM Computing Surveys, vol.43, issue.1, pp.1-534, 2010. ,
DOI : 10.1145/1824795.1824800
A new tree type data structure with homogeneous nodes suitable for a very large spatial database, [1990] Proceedings. Sixth International Conference on Data Engineering, pp.296-303, 1990. ,
DOI : 10.1109/ICDE.1990.113481
Network-Aware Operator Placement for Stream-Processing Systems, 22nd International Conference on Data Engineering (ICDE'06), p.49, 2006. ,
DOI : 10.1109/ICDE.2006.105
OGC R sensor web enablement: Overview and high level achhitecture, IEEE, pp.372-380, 2007. ,
Fulfilling end-to-end latency constraints in large-scale streaming environments, 30th IEEE International Performance Computing and Communications Conference, pp.1-8, 2011. ,
DOI : 10.1109/PCCC.2011.6108086
Operator placement for in-network stream query processing, Proceedings of the twenty-fourth ACM SIGMOD-SIGACT-SIGART symposium on Principles of database systems , PODS '05, pp.250-258, 2005. ,
DOI : 10.1145/1065167.1065199
Distributed spectral cluster management, Proceedings of the 6th ACM International Conference on Distributed Event-Based Systems, DEBS '12, pp.213-224, 2012. ,
DOI : 10.1145/2335484.2335508
Efficient content-based routing with network topology inference, Proceedings of the 7th ACM international conference on Distributed event-based systems, DEBS '13, pp.51-62, 2013. ,
DOI : 10.1145/2488222.2488262
A survey of application level multicast techniques, Computer Communications, vol.27, issue.15, pp.1547-1568, 2004. ,
DOI : 10.1016/j.comcom.2004.04.003
