Conference papers
SINGLE-CHANNEL SPEAKER-DEPENDENT SPEECH ENHANCEMENT EXPLOITING GENERIC NOISE MODEL LEARNED BY NON-NEGATIVE MATRIX FACTORIZATION
Abstract : This paper considers the single-channel speech separation problem given a noisy observation recorded by a microphone. More precisely, we focus on the speaker-dependent approach where spectral characteristic of target speech is learned in advance from a clean example. In training process, we propose to learn a generic spectral model for noise source by collecting various types of environmental noise via the established non-negative matrix factorization framework. In speech enhancement process, we propose to combine two existing group sparsity-inducing penalties in the optimization function and derive the corresponding algorithm for parameter estimation based on multiplicative update (MU) rule. Experiment result over mixtures containing different real-world noises confirms the effectiveness of our approach.
Complete list of metadata
Cited literature [7 references]  Display  Hide  Download
https://hal.inria.fr/hal-01288277
Contributor : Ngoc Duong Connect in order to contact the contributor
Submitted on : Tuesday, March 15, 2016 - 11:07:10 AM
Last modification on : Friday, May 13, 2022 - 1:54:02 PM
Long-term archiving on: : Thursday, June 16, 2016 - 10:39:47 AM
File
iceic2016_Edit2.pdf
Identifiers
  • HAL Id : hal-01288277, version 1
Collections
UGA | CNRS
Citation
Hien-Thanh Duong, Quoc-Cuong Nguyen, Cong-Phuong Nguyen, Ngoc Q. K. Duong. SINGLE-CHANNEL SPEAKER-DEPENDENT SPEECH ENHANCEMENT EXPLOITING GENERIC NOISE MODEL LEARNED BY NON-NEGATIVE MATRIX FACTORIZATION. IEEE International Conference on Electronics, Information and Communication, Jan 2016, Da Nang, Vietnam. ⟨hal-01288277⟩
Share
Metrics
Record views
60
Files downloads
162
