New interface
Journal articles
A method to estimate the size and characteristics of HIV-positive populations using an individual-based stochastic simulation model
Abstract : It is important not only to collect epidemiologic data on HIV but to also fully utilize such information to understand the epidemic over time and to help inform and monitor the impact of policies and interventions. We describe and apply a novel method to estimate the size and characteristics of HIV-positive populations. The method was applied to data on men who have sex with men living in the UK and to a pseudo dataset to assess performance for different data availability. The individual-based simulation model was calibrated using an approximate Bayesian computation-based approach. In 2013, 48,310 (90% plausibility range: 39,900–45,560) men who have sex with men were estimated to be living with HIV in the UK, of whom 10,400 (6,160–17,350) were undiagnosed. There were an estimated 3,210 (1,730–5,350) infections per year on average between 2010 and 2013. Sixty-two percent of the total HIV-positive population are thought to have viral load <500 copies/ml. In the pseudo-epidemic example, HIV estimates have narrower plausibility ranges and are closer to the true number, the greater the data availability to calibrate the model. We demonstrate that our method can be applied to settings with less data, however plausibility ranges for estimates will be wider to reflect greater uncertainty of the data used to fit the model.
Complete list of metadata
https://hal.inria.fr/hal-01288889
Contributor : Sandrine DARMIGNY Connect in order to contact the contributor
Submitted on : Tuesday, March 15, 2016 - 4:52:15 PM
Last modification on : Tuesday, August 16, 2022 - 5:36:40 PM
Links full text
Identifiers
Collections
Citation
Fumiyo Nakagawa, Ard van Sighem, Rodolphe Thiébaut, Colette Smith, Oliver Ratmann, et al.. A method to estimate the size and characteristics of HIV-positive populations using an individual-based stochastic simulation model. Epidemiology, 2016, 27 (2), pp.247-256. ⟨10.1097/EDE.0000000000000423⟩. ⟨hal-01288889⟩
Share
Metrics
Record views
145
