An Efficient Attack on a Code-Based Signature Scheme - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Baldi et al. have introduced in [BBC + 13] a very novel code based signature scheme. However we will prove here that some of the bits of the signatures are correlated in this scheme and this allows an attack that recovers enough of the underlying secret structure to forge new signatures. This cryptanalysis was performed on the parameters which were devised for 80 bits of security and broke them with 100, 000 signatures originating from the same secret key.
article.pdf (403.65 Ko) Télécharger le fichier
hal-01289044 , version 1 (16-03-2016)
Aurélie Phesso, Jean-Pierre Tillich. An Efficient Attack on a Code-Based Signature Scheme. Post-Quantum Cryptography - 7th International Workshop, PQCrypto 2016, Feb 2016, Fukuoka, Japan. pp.86-103, ⟨10.1007/978-3-319-29360-8_7⟩. ⟨hal-01289044⟩
Collections
INRIA INRIA2
305 Consultations
314 Téléchargements
