Missing boundary data reconstruction via an approximate optimal control, Inverse Problems and Imaging, vol.2, issue.4, pp.411-426, 2008. ,
DOI : 10.3934/ipi.2008.2.411
Solving Cauchy problems by minimizing an energy-like functional, Inverse Problems, vol.22, issue.1, pp.115-133, 2006. ,
DOI : 10.1088/0266-5611/22/1/007
URL : https://hal.archives-ouvertes.fr/hal-00139569
Solving elliptic boundary value problems with uncertain coefficients by the finite element method: the stochastic formulation, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.12-16, pp.1251-1294, 2005. ,
DOI : 10.1016/j.cma.2004.02.026
Galerkin Finite Element Approximations of Stochastic Elliptic Partial Differential Equations, SIAM Journal on Numerical Analysis, vol.42, issue.2, pp.800-825, 2005. ,
DOI : 10.1137/S0036142902418680
An adaptive algorithm to build up sparse polynomial chaos expansions for stochastic finite element analysis, Probabilistic Engineering Mechanics, pp.183-197, 2010. ,
DOI : 10.1016/j.probengmech.2009.10.003
Mathematical Modeling of Electrocardiograms: A Numerical Study, Annals of Biomedical Engineering, vol.98, issue.1???3, pp.1071-1097, 2010. ,
DOI : 10.1007/s10439-009-9873-0
URL : https://hal.archives-ouvertes.fr/inria-00400490
Stochastic Optimal Robin Boundary Control Problems of Advection-Dominated Elliptic Equations, SIAM Journal on Numerical Analysis, vol.51, issue.5, pp.3163-3185, 2013. ,
DOI : 10.1137/120884158
Localization of the origin of premature beats using anintegral method, International Journal of Bioelectromagnetism, vol.13, pp.178-183, 2011. ,
Physical Properties of Tissue: A Comprehensive Reference Book, 1990. ,
Computational aspects of the stochastic finite element method, Computing and Visualization in Science, vol.191, issue.2, pp.3-15, 2007. ,
DOI : 10.1007/s00791-006-0047-4
The electric resistivity of human tissues (100 Hz-10 MHz): a meta-analysis of review studies, Physiological Measurement, vol.20, issue.4, pp.1-11, 1999. ,
DOI : 10.1088/0967-3334/20/4/201
Decoupled time-marching schemes in computational cardiac electrophysiology and ECG numerical simulation, Mathematical Biosciences, vol.226, issue.1, pp.58-75, 2010. ,
DOI : 10.1016/j.mbs.2010.04.003
Dielectric properties of tissues and biological materials: a critical review, Critical reviews in biomedical engineering, vol.17, issue.1, pp.25-104, 1988. ,
The dielectric properties of biological tissues: II. Measurements in the frequency range 10 Hz to 20 GHz, Physics in Medicine and Biology, vol.41, issue.11, pp.4122-51, 1996. ,
DOI : 10.1088/0031-9155/41/11/002
Application of Stochastic Finite Element Methods to Study the Sensitivity of ECG Forward Modeling to Organ Conductivity, IEEE Transactions on Biomedical Engineering, vol.55, issue.1, pp.31-40, 2008. ,
DOI : 10.1109/TBME.2007.900563
Stochastic Finite Elements:a Spectral Approach, 1991. ,
Application of L1-Norm Regularization to Epicardial Potential Solution of the Inverse Electrocardiography Problem, Annals of Biomedical Engineering, vol.289, issue.5, pp.902-912, 2009. ,
DOI : 10.1007/s10439-009-9665-6
The Use of the L-Curve in the Regularization of Discrete Ill-Posed Problems, SIAM Journal on Scientific Computing, vol.14, issue.6, pp.1487-1503, 1993. ,
DOI : 10.1137/0914086
Finite element approximations of stochastic optimal control problems constrained by stochastic elliptic PDEs, Journal of Mathematical Analysis and Applications, vol.384, issue.1, pp.87-103, 2011. ,
DOI : 10.1016/j.jmaa.2010.07.036
A Stochastic Projection Method for Fluid Flow, Journal of Computational Physics, vol.173, issue.2, pp.9-44, 2002. ,
DOI : 10.1006/jcph.2001.6889
The effect of torso inhomogeneities on body surface potentials quantified using ???tailored??? geometry, Journal of Electrocardiology, vol.22, issue.1, pp.53-72, 1989. ,
DOI : 10.1016/0022-0736(89)90023-X
Complétion de données via des méthodes de type controle, 2009. ,
Denis, and al. Non invasive ecg mapping to guide catheter ablation, JAFIB: Journal of Atrial Fibrillation, vol.7, issue.3, p.2014 ,
Predicting tissue conductivity influences on body surface potentialsan efficient approach based on principal component analysis, Biomedical Engineering IEEE Transactions, vol.58, issue.2, pp.256-273, 2011. ,
The Homogeneous Chaos, American Journal of Mathematics, vol.60, issue.4, pp.897-936, 1998. ,
DOI : 10.2307/2371268
The Wiener--Askey Polynomial Chaos for Stochastic Differential Equations, SIAM Journal on Scientific Computing, vol.24, issue.2, pp.619-644, 2002. ,
DOI : 10.1137/S1064827501387826
Algorithms and numerical analysis of dc fields in a piecewise-homogeneous medium by the boundary integral equation method, Computational Mathematics and Modeling, vol.21, issue.5, pp.247-257, 2009. ,
DOI : 10.1007/s10598-009-9034-1
