Exponential stability of stationary distributions of a mean field of spiking neural network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2016
Audric Drogoul
  • Fonction : Auteur
  • PersonId : 980735
Romain Veltz
In this work, we study the exponential stability of the stationary distribution of a McKean-Vlasov equation recently derived in \cite{de_masi_hydrodynamic_2015,fournier_toy_2016}. We complete the convergence result proved in \cite{fournier_toy_2016} using tools from dynamical systems theory. Our proof relies on two principal arguments. First, the linearized semigroup is positive which allows to precisely pinpoint the spectrum of the infinitesimal generator. Second, we use a time rescaling argument to transform the original quasilinear equation into another one for which the nonlinear flow is differentiable. Interestingly, this convergence result can be interpreted as the existence of a locally exponentially attracting center manifold for a hyperbolic equation.
8899.pdf (678.62 Ko) Télécharger le fichier
rapport-hal.pdf (737.48 Ko) Télécharger le fichier
hal-01290264 , version 1 (08-04-2016)
hal-01290264 , version 2 (13-04-2018)
  • HAL Id : hal-01290264 , version 1
Audric Drogoul, Romain Veltz. Exponential stability of stationary distributions of a mean field of spiking neural network. [Research Report] RR-8899, INRIA Sophia Antipolis - Méditerranée. 2016. ⟨hal-01290264v1⟩
567 Consultations
415 Téléchargements
