Exponential stability of the stationary distribution of a mean field of spiking neural network
In this work, we study the exponential stability of the stationary distribution of a McKean-Vlasov equation, of nonlinear hyperbolic type which was recently derived in \cite{de_masi_hydrodynamic_2015,fournier_toy_2016}. We complement the convergence result proved in \cite{fournier_toy_2016} using tools from dynamical systems theory. Our proof relies on two principal arguments in addition to a Picard-like iteration method. First, the linearized semigroup is positive which allows to precisely pinpoint the spectrum of the infinitesimal generator. Second, we use a time rescaling argument to transform the original quasilinear equation into another one for which the nonlinear flow is differentiable. Interestingly, this convergence result can be interpreted as the existence of a locally exponentially attracting center manifold for a hyperbolic equation.
