2IECL - Institut Élie Cartan de Lorraine (Université de Lorraine, Boulevard des Aiguillettes BP 70239 54506 Vandoeuvre-les-Nancy Cedex
Ile du Saulcy - 57 045 Metz Cedex 01 - France)
Abstract : The density classification problem is the computational problem of finding the majority in a given array of votes in a distributed fashion. It is known that no cellular automaton rule with binary alphabet can solve the density classification problem. On the other hand, it was shown that a probabilistic mixture of the traffic rule and the majority rule solves the one-dimensional problem correctly with a probability arbitrarily close to one. We investigate the possibility of a similar approach in two dimensions. We show that in two dimensions, the particle spacing problem, which is solved in one dimension by the traffic rule, has no cellular automaton solution. However, we propose exact and randomized solutions via interacting particle systems. We assess the performance of our models using numeric simulations.
https://hal.inria.fr/hal-01290290 Contributor : Nazim FatèsConnect in order to contact the contributor Submitted on : Friday, April 1, 2016 - 10:47:23 PM Last modification on : Saturday, June 25, 2022 - 7:46:03 PM Long-term archiving on: : Wednesday, November 9, 2016 - 5:31:08 PM
Nazim Fatès, Irène Marcovici, Siamak Taati. Two-dimensional traffic rules and the density classification problem. 22th International Workshop on Cellular Automata and Discrete Complex Systems (AUTOMATA), Jun 2016, Zürich, France. pp.135-148, ⟨10.1007/978-3-319-39300-1_11⟩. ⟨hal-01290290⟩
