Fitting a morphable model to 3D scans of faces, ICCV, 2007. ,
A morphable model for the synthesis of 3D faces, SIGGRAPH, pp.187-194, 1999. ,
3D faces in motion: Fully automatic registration and statistical analysis, vol.131, pp.100-115, 2015. ,
A groupwise multilinear correspondence optimization for 3D faces, ICCV, pp.3604-3612, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01205460
Robust multilinear model framework, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01290783
Multilinear wavelets: A statistical shape space for human faces, ECCV, pp.297-312, 2014. ,
Review of statistical shape spaces for 3D data with comparative analysis for human faces, CVIU, vol.128, issue.0, pp.1-17, 2014. ,
Compact part-based shape spaces for dense correspondences, 2013. ,
Robust principal component analysis?, J. ACM, vol.58, issue.3, 2011. ,
Exact matrix completion via convex optimization, Found. Comput. Math, vol.9, issue.6, pp.717-772, 2009. ,
3D shape regression for real-time facial animation, TOG (Proc. SIGGRAPH), vol.32, 2013. ,
3D point correspondence by minimum description length in feature space, ECCV, pp.621-634, 2010. ,
Simultaneous tensor decomposition and completion using factor priors, vol.36, pp.577-591, 2014. ,
, Video face replacement. TOG (Proc. SIGGRAPH Asia), vol.30, pp.130-131, 2011.
Statistical Models of Shape: Optimisation and Evaluation, 2008. ,
Statistical shape analysis, 1998. ,
Automatic landmark annotation and dense correspondence registration for 3D human facial images, BMC Bioinf, vol.14, issue.1, 2013. ,
Coregistration: Simultaneous alignment and modeling of articulated 3D shape, ECCV, pp.242-255, 2012. ,
Unconstrained realtime facial performance capture, CVPR, pp.1675-1683, 2015. ,
Interactive multi-resolution modeling on arbitrary meshes, SIGGRAPH, pp.105-114, 1998. ,
Automatic construction of eigenshape models by direct optimization, Image Anal, vol.2, issue.4, pp.303-314, 1998. ,
Signal processing based on multilinear algebra, 1997. ,
Practice and theory of blendshape facial models, EG -STARs, 2014. ,
, Realtime facial animation with on-the-fly correctives. TOG (Proc. SIGGRAPH), vol.32, 2013.
On the limited memory method for large scale optimization, Math. Prog.: Series A and B, vol.45, issue.3, pp.503-528, 1989. ,
Tensor completion for estimating missing values in visual data, PAMI, vol.35, issue.1, pp.208-220, 2013. ,
Bilinear models for 3-D face and facial expression recognition, IFS, vol.3, pp.498-511, 2008. ,
A modification of threshold accepting and its application to the quadratic assignment problem, OR Spektrum, vol.17, issue.2-3, pp.205-210, 1995. ,
Fully automatic expression-invariant face correspondence, MVAP, vol.25, issue.4, pp.859-879, 2014. ,
Static and dynamic 3D facial expression recognition: A comprehensive survey, Image Vision Comput, vol.30, pp.683-697, 2012. ,
Bosphorus database for 3D face analysis, BIOID, pp.47-56, 2008. ,
Probabilistic principal component analysis, J. R. Stat. Soc. Ser. B Stat. Methodol, vol.61, pp.611-622, 1999. ,
Face transfer with multilinear models, TOG (Proc. SIGGRAPH), vol.24, issue.3, pp.426-433, 2005. ,
Facial expression editing in video using a temporally-smooth factorization, CVPR, pp.861-868, 2012. ,
A 3D facial expression database for facial behavior research, FG, pp.211-216, 2006. ,
Exact tensor completion using t-svd, 2015. ,
