Fiber composition of the human corpus callosum, Brain Research, vol.598, issue.1-2, pp.143-153, 1992. ,
DOI : 10.1016/0006-8993(92)90178-C
Reconstruction of the orientation distribution function in single- and multiple-shell q-ball imaging within constant solid angle, Magnetic Resonance in Medicine, vol.27, pp.554-566, 2010. ,
DOI : 10.1002/mrm.22365
A general framework for experiment design in diffusion MRI and its application in measuring direct tissue-microstructure features, Magnetic Resonance in Medicine, vol.12, issue.2, pp.439-448, 2008. ,
DOI : 10.1002/mrm.21646
Orientationally invariant indices of axon diameter and density from diffusion MRI, NeuroImage, vol.52, issue.4, pp.1374-1389, 2010. ,
DOI : 10.1016/j.neuroimage.2010.05.043
A comprehensive gaussian process framework for correcting distortions and movements in diffusion images, Proceedings of the 20th Annual Meeting of ISMRM, p.2426, 2012. ,
Axcaliber: A method for measuring axon diameter distribution from diffusion MRI, Magnetic Resonance in Medicine, vol.14, issue.6, pp.1347-1354, 2008. ,
DOI : 10.1002/mrm.21577
New modeling and experimental framework to characterize hindered and restricted water diffusion in brain white matter, Magnetic Resonance in Medicine, vol.121, issue.204, pp.965-978, 2004. ,
DOI : 10.1002/mrm.20274
Efficient and robust computation of pdf features from diffusion mr signal. Medical image analysis 13, pp.715-729, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00410615
Clinical feasibility of using mean apparent propagator (MAP) MRI to characterize brain tissue microstructure, NeuroImage, vol.127, 2015. ,
DOI : 10.1016/j.neuroimage.2015.11.027
The effect of the diffusion time and pulse gradient duration ratio on the diffraction pattern and the structural information estimated from q-space diffusion MR: Experiments and simulations, Journal of Magnetic Resonance, vol.194, issue.2, pp.230-236, 2008. ,
DOI : 10.1016/j.jmr.2008.07.009
Relationships between diffusion tensor and q-space mri. Magnetic resonance in medicine 47, pp.392-397, 2002. ,
DOI : 10.1002/mrm.10052
MR diffusion tensor spectroscopy and imaging, Biophysical Journal, vol.66, issue.1, p.259, 1994. ,
DOI : 10.1016/S0006-3495(94)80775-1
URL : https://hal.archives-ouvertes.fr/hal-00349721
Characterization and propagation of uncertainty in diffusion-weighted mr imaging. Magnetic resonance in medicine 50, pp.1077-1088, 2003. ,
Mesoscopic structure of neuronal tracts from time-dependent diffusion, NeuroImage, vol.114, pp.18-37, 2015. ,
DOI : 10.1016/j.neuroimage.2015.03.061
A Limited Memory Algorithm for Bound Constrained Optimization, SIAM Journal on Scientific Computing, vol.16, issue.5, pp.1190-1208, 1995. ,
DOI : 10.1137/0916069
Principles of nuclear magnetic resonance microscopy, 1991. ,
Pulsed-Gradient Spin-Echo NMR for Planar, Cylindrical, and Spherical Pores under Conditions of Wall Relaxation, Journal of Magnetic Resonance, Series A, vol.113, issue.1, pp.53-59, 1995. ,
DOI : 10.1006/jmra.1995.1055
Diffusion MRI signal reconstruction with continuity constraint and optimal regularization, Medical Image Analysis, vol.16, issue.6, pp.1113-1120, 2012. ,
DOI : 10.1016/j.media.2012.06.011
URL : https://hal.archives-ouvertes.fr/hal-00711883
Design of multishell sampling schemes with uniform coverage in diffusion MRI, Magnetic Resonance in Medicine, vol.103, issue.6, pp.1534-1540, 2013. ,
DOI : 10.1002/mrm.24736
URL : https://hal.archives-ouvertes.fr/hal-00821688
Estimation and Processing of Ensemble Average Propagator and Its Features in Diffusion MRI, 2014. ,
URL : https://hal.archives-ouvertes.fr/tel-00759048
Measurement of translational displacement probabilities by nmr: an indicator of compartmentation. Magnetic resonance in medicine 14, pp.435-444, 1990. ,
Smoothing noisy data with spline functions, Numerische Mathematik, vol.4, issue.4, pp.377-403, 1978. ,
DOI : 10.1007/BF01404567
Regularized, fast, and robust analytical Q-ball imaging, Magnetic Resonance in Medicine, vol.17, issue.3, pp.497-510, 2007. ,
DOI : 10.1002/mrm.21277
Multiple q-shell diffusion propagator imaging, Medical Image Analysis, vol.15, issue.4, pp.603-621, 2011. ,
DOI : 10.1016/j.media.2010.07.001
URL : https://hal.archives-ouvertes.fr/hal-00531473
Multiplexed echo planar imaging for sub-second whole brain fmri and fast diffusion imaging, PloS one, vol.5, 2010. ,
DOI : 10.1371/journal.pone.0015710
A sensitivity analysis of q-space indices with respect to changes in axonal diameter, dispersion and tissue composition, 2016 IEEE 13th International Symposium on Biomedical Imaging (ISBI), 2016. ,
DOI : 10.1109/ISBI.2016.7493491
URL : https://hal.archives-ouvertes.fr/hal-01292013
Using 3D-SHORE and MAP-MRI to obtain both tractography and microstructural constrast from a clinical DMRI acquisition, 2015 IEEE 12th International Symposium on Biomedical Imaging (ISBI), 2015. ,
DOI : 10.1109/ISBI.2015.7163905
URL : https://hal.archives-ouvertes.fr/hal-01140011
A Unifying Framework for Spatial and Temporal Diffusion in Diffusion MRI, International Processing in Medical Imaging (IPMI), 2015. ,
DOI : 10.1007/978-3-319-19992-4_13
URL : https://hal.archives-ouvertes.fr/hal-01140070
Dipy, a library for the analysis of diffusion MRI data, Frontiers in neuroinformatics 8, 2014. ,
DOI : 10.1109/TMI.2010.2045126
The minimal preprocessing pipelines for the Human Connectome Project, NeuroImage, vol.80, pp.105-124, 2013. ,
DOI : 10.1016/j.neuroimage.2013.04.127
Accurate and robust brain image alignment using boundary-based registration, NeuroImage, vol.48, issue.1, pp.63-72, 2009. ,
DOI : 10.1016/j.neuroimage.2009.06.060
Wu-minn hcp 500 subjects + meg2 release: Reference manual URL: http:// www.humanconnectome.org/documentation/S500/HCP_S500+MEG2_Release_Appendix_I.pdf. [Online; accessed 25, 2014. ,
Bessel Fourier Orientation Reconstruction (BFOR): An analytical diffusion propagator reconstruction for hybrid diffusion imaging and computation of q-space indices, NeuroImage, vol.64, pp.650-670, 2013. ,
DOI : 10.1016/j.neuroimage.2012.08.072
The impact of gradient strength on in vivo diffusion MRI estimates of axon diameter, NeuroImage, vol.106, pp.464-472, 2015. ,
DOI : 10.1016/j.neuroimage.2014.12.008
Plasticity of left perisylvian white-matter tracts is associated with individual differences in math learning, Brain Structure and Function, vol.54, issue.2, pp.1-15, 2015. ,
DOI : 10.1007/s00429-014-0975-6
URL : https://hal.archives-ouvertes.fr/hal-01099660
A 64-channel 3T array coil for accelerated brain MRI, Magnetic Resonance in Medicine, vol.16, issue.1, pp.248-258, 2013. ,
DOI : 10.1002/mrm.24427
A signal transformational framework for breaking the noise floor and its applications in MRI, Journal of Magnetic Resonance, vol.197, issue.2, pp.108-119, 2009. ,
DOI : 10.1016/j.jmr.2008.11.015
Accuracy of <formula><tex>$q$</tex></formula>-Space Related Parameters in MRI: Simulations and Phantom Measurements, IEEE Transactions on Medical Imaging, vol.26, issue.11, pp.1437-1447, 2007. ,
DOI : 10.1109/TMI.2007.907278
Imagerie de diffusion in-vivo par résonance magnétique nucléaire. Comptes-Rendus de l, Académie des Sciences, vol.93, pp.27-34, 1985. ,
Quantitative Histological Validation of Diffusion MRI Fiber Orientation Distributions in the Rat Brain, PLoS ONE, vol.111, issue.1, 2010. ,
DOI : 10.1371/journal.pone.0008595.g005
Distribution of axon diameters in cortical white matter: an electron-microscopic study on three human brains and a macaque, Biological Cybernetics, vol.30, issue.44, pp.541-557, 2014. ,
DOI : 10.1007/s00422-014-0626-2
Self-diffusion NMR imaging using stimulated echoes, Journal of Magnetic Resonance (1969), vol.64, issue.3, pp.479-486, 1969. ,
DOI : 10.1016/0022-2364(85)90111-8
Continuous diffusion signal, EAP and ODF estimation via Compressive Sensing in diffusion MRI, Medical Image Analysis, vol.17, issue.5, pp.556-572, 2013. ,
DOI : 10.1016/j.media.2013.02.010
URL : https://hal.archives-ouvertes.fr/hal-00815108
Multiband multislice GE-EPI at 7 tesla, with 16-fold acceleration using partial parallel imaging with application to high spatial and temporal whole-brain fMRI, Magnetic Resonance in Medicine, vol.54, issue.5, pp.1144-1153, 2010. ,
DOI : 10.1002/mrm.22361
Novel spherical phantoms for Q-ball imaging under in vivo conditions, Magnetic Resonance in Medicine, vol.79, issue.1, pp.190-194, 2011. ,
DOI : 10.1002/mrm.22602
The role of tissue microstructure and water exchange in biophysical modelling of diffusion in white matter, Magnetic Resonance Materials in Physics, Biology and Medicine, vol.51, issue.2, pp.345-370, 2013. ,
DOI : 10.1007/s10334-013-0371-x
Sparse reconstruction challenge for diffusion mri: Validation on a physical phantom to determine which acquisition scheme and analysis method to use? Medical image analysis 26, pp.316-331, 2015. ,
Revealing mesoscopic structural universality with diffusion, Proceedings of the National Academy of Sciences, vol.111, issue.14, pp.5088-5093, 2014. ,
DOI : 10.1073/pnas.1316944111
Simple Harmonic Oscillator Based Reconstruction and Estimation for One-Dimensional q-Space Magnetic Resonance (1D-SHORE), pp.373-399, 2013. ,
DOI : 10.1007/978-0-8176-8379-5_19
Mean apparent propagator (MAP) MRI: A novel diffusion imaging method for mapping tissue microstructure, NeuroImage, vol.78, pp.16-32, 2013. ,
DOI : 10.1016/j.neuroimage.2013.04.016
Nuclear magnetic resonance characterization of general compartment size distributions, New Journal of Physics, vol.13, issue.1, 2011. ,
DOI : 10.1088/1367-2630/13/1/015010
Temporal scaling characteristics of diffusion as a new MRI contrast: Findings in rat hippocampus, NeuroImage, vol.60, issue.2, pp.1380-1393, 2012. ,
DOI : 10.1016/j.neuroimage.2012.01.105
Compartment models of the diffusion MR signal in brain white matter: A taxonomy and comparison, NeuroImage, vol.59, issue.3, pp.2241-2254, 2012. ,
DOI : 10.1016/j.neuroimage.2011.09.081
Multi-shell diffusion signal recovery from sparse measurements. Medical image analysis 18, pp.1143-1156 ,
DOI : 10.1016/j.media.2014.06.003
Microstructural organization of axons in the human corpus callosum quantified by diffusion-weighted magnetic resonance spectroscopy of N-acetylaspartate and post-mortem histology, Brain Structure and Function, vol.56, issue.3, pp.1773-1785, 2014. ,
DOI : 10.1007/s00429-013-0600-0
Blipped-controlled aliasing in parallel imaging for simultaneous multislice echo planar imaging with reduced g-factor penalty, Magnetic Resonance in Medicine, vol.62, issue.3, pp.1210-1224, 2012. ,
DOI : 10.1002/mrm.23097
Pushing the limits of in vivo diffusion MRI for the Human Connectome Project, NeuroImage, vol.80, pp.220-233, 2013. ,
DOI : 10.1016/j.neuroimage.2013.05.078
Restricted Self???Diffusion of Protons in Colloidal Systems by the Pulsed???Gradient, Spin???Echo Method, The Journal of Chemical Physics, vol.49, issue.4, pp.1768-1777, 1968. ,
DOI : 10.1063/1.1670306
The spatial mapping of translational diffusion coefficients by the NMR imaging technique, Physics in Medicine and Biology, vol.30, issue.4, p.345, 1985. ,
DOI : 10.1088/0031-9155/30/4/009
Q-ball imaging, Magnetic Resonance in Medicine, vol.23, issue.6, pp.1358-1372, 2004. ,
DOI : 10.1002/mrm.20279
The WU-Minn Human Connectome Project: An overview, NeuroImage, vol.80, pp.62-79, 2013. ,
DOI : 10.1016/j.neuroimage.2013.05.041
Evaluation of Restricted Diffusion in Cylinders. Phosphocreatine in Rabbit Leg Muscle, Journal of Magnetic Resonance, Series B, vol.103, issue.3, pp.255-260, 1994. ,
DOI : 10.1006/jmrb.1994.1038
Properties of hermite series estimation of probability density. The Annals of Statistics, pp.1258-1264, 1977. ,
Mapping complex tissue architecture with diffusion spectrum magnetic resonance imaging, Magnetic Resonance in Medicine, vol.118, issue.6, pp.1377-1386, 2005. ,
DOI : 10.1002/mrm.20642
Computation of diffusion function measures in-space using magnetic resonance hybrid diffusion imaging, Medical Imaging IEEE Transactions on, vol.27, pp.858-865, 2008. ,
Highly accelerated whole brain imaging using aligned-blipped-controlled-aliasing multiband epi, Proceedings of the 20th Annual Meeting of ISMRM, 2012. ,
Development of white matter and reading skills, Proceedings of the National Academy of Sciences, vol.109, issue.44, pp.3045-3053, 2012. ,
DOI : 10.1073/pnas.1206792109
NODDI: Practical in vivo neurite orientation dispersion and density imaging of the human brain, NeuroImage, vol.61, issue.4, pp.1000-1016, 2012. ,
DOI : 10.1016/j.neuroimage.2012.03.072
