Abstract : Given any two vertices u, v of a random geometric graph G(n, r), denote by d_E(u, v) their Euclidean distance and by d_G(u, v) their graph distance. The problem of finding upper bounds on d_G(u, v) conditional on d_E(u, v) that hold asymptotically almost surely has received quite a bit of attention in the literature. In this paper, we improve the known upper bounds for values of r = \omega\sqrt(log n)) (i.e. for r above the connectivity threshold). Our result also improves the best known estimates on the diameter of random geometric graphs. We also provide a lower bound on d_G(u, v) conditional on d_E(u, v).
