Controllability of the Schrödinger equation via intersection of eigenvalues, Proceedings of the 44th IEEE Conference on Decision and Control, pp.1080-1085, 2005. ,
Bounds on exponential decay of eigenfunctions of Schr??dinger operators, Schrödinger operators, pp.1-38, 1984. ,
DOI : 10.1007/BFb0080331
Controllability of 2D Euler and Navier-Stokes Equations by Degenerate Forcing, Communications in Mathematical Physics, vol.37, issue.3, pp.673-697, 2006. ,
DOI : 10.1007/s00220-006-0002-8
Genericity of simple eigenvalues for elliptic PDE's, Proc. Amer, pp.413-418, 1975. ,
Controllability for Distributed Bilinear Systems, SIAM Journal on Control and Optimization, vol.20, issue.4, pp.575-597, 1982. ,
DOI : 10.1137/0320042
Spectral controllability for 2D and 3D linear Schr??dinger equations, Journal of Functional Analysis, vol.256, issue.12, pp.3916-3976, 2009. ,
DOI : 10.1016/j.jfa.2009.02.009
Controllability of a quantum particle in a moving potential well, Journal of Functional Analysis, vol.232, issue.2, pp.328-389, 2006. ,
DOI : 10.1016/j.jfa.2005.03.021
URL : https://hal.archives-ouvertes.fr/hal-00825517
Local controllability of 1D linear and nonlinear Schr??dinger equations with bilinear control, Journal de Math??matiques Pures et Appliqu??es, vol.94, issue.5, pp.520-554, 2010. ,
DOI : 10.1016/j.matpur.2010.04.001
Semi-global weak stabilization of bilinear Schrödinger equations, C. R. Math. Acad. Sci. Paris, vol.348, pp.19-201073, 2010. ,
Quantum control of infinite-dimensional many-body systems, Physical Review A, vol.89, issue.3, p.32309, 2014. ,
DOI : 10.1103/PhysRevA.89.032309
Finite Controllability of Infinite-Dimensional Quantum Systems, IEEE Transactions on Automatic Control, vol.55, issue.8, pp.551797-1805, 2010. ,
DOI : 10.1109/TAC.2010.2044273
A Weak Spectral Condition for the Controllability of the Bilinear Schr??dinger Equation with Application to the Control of a Rotating Planar Molecule, Communications in Mathematical Physics, vol.75, issue.4, pp.423-455, 2012. ,
DOI : 10.1007/s00220-012-1441-z
Multi-input Schr??dinger equation: Controllability, tracking, and application to the quantum angular momentum, Journal of Differential Equations, vol.256, issue.11, pp.3524-3551, 2014. ,
DOI : 10.1016/j.jde.2014.02.004
Adiabatic Control of the Schr??dinger Equation via Conical Intersections of the Eigenvalues, IEEE Transactions on Automatic Control, vol.57, issue.8, pp.1970-1983, 2012. ,
DOI : 10.1109/TAC.2012.2195862
Periodic excitations of bilinear quantum systems, Automatica, vol.48, issue.9, pp.2040-2046, 2012. ,
DOI : 10.1016/j.automatica.2012.03.031
URL : https://hal.archives-ouvertes.fr/hal-00594895
Controllability of the discrete-spectrum Schr??dinger equation driven by an external field, Annales de l'Institut Henri Poincare (C) Non Linear Analysis, vol.26, issue.1, pp.329-349, 2009. ,
DOI : 10.1016/j.anihpc.2008.05.001
Spektraltheorie halbbeschr???nkter Operatoren und Anwendung auf die Spektralzerlegung von Differentialoperatoren, Mathematische Annalen, vol.3, issue.1, pp.465-487, 1934. ,
DOI : 10.1007/BF01449150
Perturbation theory for linear operators Die Grundlehren der mathematischen Wissenschaften, 1966. ,
Controlling several atoms in a cavity, New Journal of Physics, vol.16, issue.6, p.65010, 2014. ,
DOI : 10.1088/1367-2630/16/6/065010
Approximate controllability via adiabatic techniques for the three-inputs controlled Schrödinger equation ,
Generic Controllability Properties for the Bilinear Schr??dinger Equation, Communications in Partial Differential Equations, vol.74, issue.4, pp.685-706, 2010. ,
DOI : 10.2307/2374041
Lyapunov control of a quantum particle in a decaying potential, Annales de l'Institut Henri Poincare (C) Non Linear Analysis, vol.26, issue.5, pp.1743-1765, 2009. ,
DOI : 10.1016/j.anihpc.2008.09.006
URL : https://hal.archives-ouvertes.fr/hal-00793568
Simultaneous global exact controllability of an arbitrary number of 1d bilinear Schr??dinger equations, Journal de Math??matiques Pures et Appliqu??es, vol.103, issue.1, pp.228-254, 2015. ,
DOI : 10.1016/j.matpur.2014.04.002
Growth of Sobolev Norms and Controllability of the Schr??dinger Equation, Communications in Mathematical Physics, vol.33, issue.12, pp.371-387, 2009. ,
DOI : 10.1007/s00220-009-0842-0
Global approximate controllability for Schr??dinger equation in higher Sobolev norms and applications, Annales de l'Institut Henri Poincare (C) Non Linear Analysis, vol.27, issue.3, pp.901-915, 2010. ,
DOI : 10.1016/j.anihpc.2010.01.004
Global exact controllability in infinite time of Schr??dinger equation, Journal de Math??matiques Pures et Appliqu??es, vol.97, issue.4, pp.295-317, 2012. ,
DOI : 10.1016/j.matpur.2011.11.005
The squares of the Laplacian-Dirichlet eigenfunctions are generically linearly independent, ESAIM: Control, Optimisation and Calculus of Variations, vol.16, issue.3, pp.794-805, 2010. ,
DOI : 10.1051/cocv/2009014
URL : https://hal.archives-ouvertes.fr/hal-00322301
Methods of modern mathematical physics. IV. Analysis of operators, 1978. ,
Perturbation theory of Schr??dinger operators in infinitely many coupling parameters, Journal of Physics A: Mathematical and General, vol.32, issue.43, pp.7523-7541, 1999. ,
DOI : 10.1088/0305-4470/32/43/307
Navier-Stokes Equation on the Rectangle: Controllability by Means of Low Mode Forcing, Journal of Dynamical and Control Systems, vol.., issue.4, pp.517-562, 2006. ,
DOI : 10.1007/s10883-006-0004-z
On the controllability of bilinear quantum systems, Mathematical models and methods for ab initio Quantum Chemistry, 2000. ,
DOI : 10.1007/978-3-642-57237-1_4
URL : https://hal.archives-ouvertes.fr/hal-00536518
