Interval observer for a class of uncertain nonlinear singular systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2016
This paper investigates the problem of observer design for a general class of linear singular time-delay systems, in which the time delays are involved in the state, the output and the known input (if there exists). The involvement of the delay could be multiple which however is rarely studied in the literature. Sufficient conditions are proposed which guarantees the existence of a Luenberger-like observer for the general system.
Automatique
Int_SS.pdf (298.02 Ko) Télécharger le fichier
hal-01292475 , version 1 (23-03-2016)
Gang Zheng, Denis Efimov, Francisco Javier Bejarano, Wilfrid Perruquetti, Haoping Wang. Interval observer for a class of uncertain nonlinear singular systems. Automatica, 2016, 71, pp.159-168. ⟨10.1016/j.automatica.2016.04.002⟩. ⟨hal-01292475⟩
279 Consultations
354 Téléchargements
