Observability and detectability analysis of singular linear systems with unknown inputs, IEEE Conference on Decision and Control and European Control Conference, pp.4005-4010, 2011. ,
DOI : 10.1109/CDC.2011.6161325
URL : https://hal.archives-ouvertes.fr/inria-00626982
State reconstruction of nonlinear differential-algebraic systems with unknown inputs, 2012 IEEE 51st IEEE Conference on Decision and Control (CDC), pp.5882-5887, 2012. ,
DOI : 10.1109/CDC.2012.6426832
URL : https://hal.archives-ouvertes.fr/hal-00731718
Observability and detectability of singular linear systems with unknown inputs, Automatica, vol.49, issue.3, pp.793-800, 2013. ,
DOI : 10.1016/j.automatica.2012.11.043
URL : https://hal.archives-ouvertes.fr/hal-00753706
Observation of Nonlinear Differential-Algebraic Systems With Unknown Inputs, IEEE Transactions on Automatic Control, vol.60, issue.7, pp.1957-1962, 2015. ,
DOI : 10.1109/TAC.2014.2363604
URL : https://hal.archives-ouvertes.fr/hal-01075275
Principle de comparaison et stabilité des systèmes complexes, 1978. ,
Vector lyapunov functions: nonlinear, time-varying, ordinary and functional differential equations Advances in Stability Theory at the End of the 20th Century, 2003. ,
Observers design for a class of nonlinear singular systems, 2012 IEEE 51st IEEE Conference on Decision and Control (CDC), 2012. ,
DOI : 10.1109/CDC.2012.6426448
URL : https://hal.archives-ouvertes.fr/hal-00753125
Observers design for non linear descriptor systems, Proc. IEEE Conf. Decision Control, 1995. ,
Singular systems of differential equations I, 1980. ,
Singular systems of differential equations II, 1982. ,
Interval observers for continuous-time LPV systems with <mml:math altimg="si1.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd" xmlns:sa="http://www.elsevier.com/xml/common/struct-aff/dtd"><mml:msub><mml:mrow><mml:mi>L</mml:mi></mml:mrow><mml:mrow><mml:mn>1</mml:mn></mml:mrow></mml:msub></mml:math>/<mml:math altimg="si2.gif" display="inline" overflow="scroll" xmlns:xocs="http://www.elsevier.com/xml/xocs/dtd" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.elsevier.com/xml/ja/dtd" xmlns:ja="http://www.elsevier.com/xml/ja/dtd" xmlns:mml="http://www.w3.org/1998/Math/MathML" xmlns:tb="http://www.elsevier.com/xml/common/table/dtd" xmlns:sb="http://www.elsevier.com/xml/common/struct-bib/dtd" xmlns:ce="http://www.elsevier.com/xml/common/dtd" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:cals="http://www.elsevier.com/xml/common/cals/dtd" xmlns:sa="http://www.elsevier.com/xml/common/struct-aff/dtd"><mml:msub><mml:mrow><mml:mi>L</mml:mi></mml:mrow><mml:mrow><mml:mn>2</mml:mn></mml:mrow></mml:msub></mml:math> performance, Automatica, vol.58, pp.82-89, 2015. ,
DOI : 10.1016/j.automatica.2015.05.009
Controllability, observability, and duality in singular systems, IEEE Transactions on Automatic Control, vol.29, issue.12, pp.1076-1082, 1984. ,
DOI : 10.1109/TAC.1984.1103451
Singular Control Systems, Lecture Notes in Control and Information Sciences, vol.118, 1989. ,
DOI : 10.1007/BFb0002475
New results on constrained stabilizing control of time-delay systems, Proceedings of 1995 34th IEEE Conference on Decision and Control, 1995. ,
DOI : 10.1109/CDC.1995.480650
Observers for a Class of Nonlinear Singular Systems, IEEE Transactions on Automatic Control, vol.53, issue.11, pp.2627-2633, 2008. ,
DOI : 10.1109/TAC.2008.2007868
Design of observers for descriptor systems, IEEE Transactions on Automatic Control, vol.40, issue.7, pp.1323-1327, 1995. ,
DOI : 10.1109/9.400467
URL : https://hal.archives-ouvertes.fr/hal-00922599
Reduced-order observer design for descriptor systems with unknown inputs, IEEE Transactions on Automatic Control, vol.41, issue.7, pp.1068-1072, 1996. ,
DOI : 10.1109/9.508918
URL : https://hal.archives-ouvertes.fr/hal-00098122
Interval estimation for LPV systems applying high order sliding mode techniques, Automatica, vol.48, issue.9, pp.2365-2371, 2012. ,
DOI : 10.1016/j.automatica.2012.06.073
URL : https://hal.archives-ouvertes.fr/hal-00701643
Interval estimation for systems with time delays and algebraic constraints, 2014 European Control Conference (ECC), 2014. ,
DOI : 10.1109/ECC.2014.6862332
URL : https://hal.archives-ouvertes.fr/hal-00986034
Interval observers for uncertain biological systems, Large Scale Systems Stability under Structural Perturbations. Lecture Notes in Control and Information Sciences, pp.45-56, 1987. ,
DOI : 10.1016/S0304-3800(00)00279-9
Causal observability of descriptor systems, IEEE Transactions on Automatic Control, vol.44, issue.1, pp.158-163, 1999. ,
DOI : 10.1109/9.739111
Observer design for descriptor systems, IEEE Transactions on Automatic Control, vol.44, issue.1, pp.164-169, 1999. ,
DOI : 10.1109/9.739112
Polynomial and Rational Matrices Applications in Dynamical Systems Theory. Communications and control engineering, 2007. ,
Zur Theorie der Systeme gew??hnlicher Differentialgleichungen. II., Acta Mathematica, vol.58, issue.0, pp.57-85, 1932. ,
DOI : 10.1007/BF02547774
An observer for a nonlinear descriptor system, [1992] Proceedings of the 31st IEEE Conference on Decision and Control, 1992. ,
DOI : 10.1109/CDC.1992.371580
Unknown input proportional multiple-integral observer design for linear descriptor systems: application to state and fault estimation, IEEE Transactions on Automatic Control, vol.50, issue.2, pp.212-217, 2005. ,
DOI : 10.1109/TAC.2004.841889
URL : https://hal.archives-ouvertes.fr/hal-00152225
Observer Design for Unknown Input Nonlinear Descriptor Systems via Convex Optimization, IEEE Transactions on Automatic Control, vol.51, issue.6, pp.1047-1052, 2006. ,
DOI : 10.1109/TAC.2006.876807
URL : https://hal.archives-ouvertes.fr/hal-00152118
Design of proportional-integral observer for unknown input descriptor systems, IEEE Transactions on Automatic Control, vol.47, issue.12, pp.2057-2062, 2002. ,
DOI : 10.1109/TAC.2002.805675
URL : https://hal.archives-ouvertes.fr/hal-00153817
Full-order and reduced-order observer for lipschitz descriptor systems: The unified lmi approach, IEEE.Trans on Circuits and systems-II: Express Briefs, vol.53, pp.563-567, 2006. ,
Asymptotically Stable Interval Observers for Planar Systems With Complex Poles, IEEE Transactions on Automatic Control, vol.55, issue.2, pp.523-527, 2010. ,
DOI : 10.1109/TAC.2009.2037472
URL : https://hal.archives-ouvertes.fr/hal-00547800
¨ uber das fundamental theorem in der theorie der gewöhnlichen differentialgleichungen, Math. Z, pp.619-645, 1926. ,
Observers for singular systems, IEEE Transactions on Automatic Control, vol.37, issue.8, pp.1211-1215, 1992. ,
DOI : 10.1109/9.151109
Connecting wasewskis conditions with mmatrices: Application to constrained stabilization, Dynam. Syst. Appl, vol.5, pp.81-96, 1996. ,
Vector lyapunov functions: Recent developments for stability, robustness, practical stability, and constrained control, Nonlinear Times and Digest, vol.2, pp.227-258, 1995. ,
On practical stability with the settling time via vector norms, International Journal of Control, vol.4, issue.1, pp.173-189, 1995. ,
DOI : 10.1073/pnas.54.1.44
Interval State Estimation for a Class of Nonlinear Systems, IEEE Transactions on Automatic Control, vol.57, issue.1, pp.260-265, 2012. ,
DOI : 10.1109/TAC.2011.2164820
Monotone dynamical systems: An introduction to the theory of competitive and cooperative systems, Surveys and Monographs, vol.41, 1995. ,
DOI : 10.1090/surv/041
Systèmes deséquationsdes´deséquations et des inégalités différentielles ordinaires aux seconds membres monotones et leurs applications, Ann. Soc. Polon. Math, vol.23, pp.112-166, 1950. ,
Observer design for a class of nonlinear descriptor systems, Proc. IEEE Conf. Decision Control, 2009. ,
Solvability, controllability, and observability of continuous descriptor systems, IEEE Transactions on Automatic Control, vol.26, issue.3, pp.702-707, 1981. ,
DOI : 10.1109/TAC.1981.1102699
Interval state estimation for uncertain nonlinear systems, IFAC Proceedings Volumes, vol.46, issue.23, 2013. ,
DOI : 10.3182/20130904-3-FR-2041.00151
URL : https://hal.archives-ouvertes.fr/hal-00844397
Design of interval observer for a class of uncertain unobservable nonlinear systems, Automatica, vol.63, pp.167-174, 2016. ,
DOI : 10.1016/j.automatica.2015.10.007
URL : https://hal.archives-ouvertes.fr/hal-01199021
