New interface
Conference papers
Efficient Large-Scale Similarity Search Using Matrix Factorization
Ahmet Iscen 1, * Michael Rabbat 2 Teddy Furon 1
* Corresponding author
1 LinkMedia - Creating and exploiting explicit links between multimedia fragments
Inria Rennes – Bretagne Atlantique , IRISA-D6 - MEDIA ET INTERACTIONS
Abstract : We consider the image retrieval problem of finding the images in a dataset that are most similar to a query image. Our goal is to reduce the number of vector operations and memory for performing a search without sacrificing accuracy of the returned images. We adopt a group testing formulation and design the decoding architecture using either dictionary learning or eigendecomposition. The latter is a plausible option for small-to-medium sized problems with high-dimensional global image descriptors, whereas dictionary learning is applicable in large-scale scenarios. We evaluate our approach for global descriptors obtained from both SIFT and CNN features.Experiments with standard image search benchmarks, including the Yahoo100M dataset comprising 100 million images, show that our method gives comparable (and sometimes superior) accuracy compared to exhaustive search while requiring only 10% of the vector operations and memory. Moreover, for the same search complexity, our method gives significantly better accuracy compared to approaches based on dimensionality reduction or locality sensitive hashing.
Document type :
Conference papers
Complete list of metadata
Cited literature [31 references]  Display  Hide  Download
https://hal.inria.fr/hal-01294736
Contributor : Ahmet Iscen Connect in order to contact the contributor
Submitted on : Tuesday, March 29, 2016 - 5:26:02 PM
Last modification on : Monday, July 25, 2022 - 3:28:15 AM
Long-term archiving on: : Thursday, June 30, 2016 - 4:31:39 PM
File
2140.pdf
Identifiers
  • HAL Id : hal-01294736, version 1
Citation
Ahmet Iscen, Michael Rabbat, Teddy Furon. Efficient Large-Scale Similarity Search Using Matrix Factorization. 2016 IEEE Conference on Computer Vision and Pattern Recognition (CVPR), Jun 2016, Las Vegas, United States. ⟨hal-01294736⟩
Share
Metrics
Record views
563
Files downloads
906
