Generalized Minimum Noise Subspace For Array Processing
Abstract : Based on the minimum noise subspace (MNS) method previously introduced in the context of blind channel identification, generalized minimum noise subspace (GMNS) is proposed in this paper for array processing that generalizes MNS with respect to the availability of only a fixed number of parallel computing units. Different batch and adaptive algorithms are then introduced for fast and parallel computation of signal (principal) and noise (minor) subspaces. The computational complexity of GMNS and its related estimation accuracy are investigated by simulated experiments and a real-life experiment in radio astronomy. It is shown that GMNS represents an excellent trade-off between the computational gain and the subspace estimation accuracy, as compared to several standard subspace methods
Type de document :
Article dans une revue
IEEE Transactions on Signal Processing, Institute of Electrical and Electronics Engineers, 2017, 64 (14), pp.3789 - 3802. 〈10.1109/TSP.2017.2695457〉
Liste complète des métadonnées
Littérature citée [26 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/hal-01295030
Contributeur : Viet-Dung Nguyen <>
Soumis le : lundi 25 juillet 2016 - 23:31:28
Dernière modification le : vendredi 4 janvier 2019 - 14:32:03
Fichier
GMNS.pdf
Fichiers produits par l'(les) auteur(s)
Distributed under a Creative Commons Paternité - Pas d'utilisation commerciale - Pas de modification 4.0 International License
Collections
OSUC | USN
Citation
Viet-Dung Nguyen, Karim Abed-Meraim, Nguyen Linh-Trung, Rodolphe Weber. Generalized Minimum Noise Subspace For Array Processing. IEEE Transactions on Signal Processing, Institute of Electrical and Electronics Engineers, 2017, 64 (14), pp.3789 - 3802. 〈10.1109/TSP.2017.2695457〉. 〈hal-01295030v2〉
Métriques
Consultations de la notice
365
Téléchargements de fichiers
169
