Parallelizing Constraint Solvers for Hard RCPSP Instances - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2016
The Resource-Constrained Project Scheduling Problem (RCPSP) is a well-known scheduling problem aimed at minimizing the makespan of a project subject to temporal and resource constraints. Constraint Programming allows to model and solve RCPSPs in a natural and efficient way, especially when Lazy Clause Generation (LCG) techniques are employed. In this paper we show that hard RCPSPs can be efficiently tackled by a portfolio approach that combines the strengths of different —not necessarily LCG-based— solvers by exploiting their parallel execution on multiple cores. Our approach seeks to predict and run the best solvers for a new, unseen RCPSP instance and also enables the bounds communication between them. This on-average allows to outperform the oracle solver that always chooses the best available solver for any given instance.
main.pdf (338.84 Ko) Télécharger le fichier
hal-01295061 , version 1 (30-03-2016)
  • HAL Id : hal-01295061 , version 1
Roberto Amadini, Maurizio Gabbrielli, Jacopo Mauro. Parallelizing Constraint Solvers for Hard RCPSP Instances. [Technical Report] Inria Sophia Antipolis. 2016. ⟨hal-01295061⟩
206 Consultations
484 Téléchargements
