On Augmented Lagrangian Methods with General Lower-Level Constraints
Abstract : Augmented Lagrangian methods with general lower-level constraints are considered in the present research. These methods are useful when efficient algorithms exist for solving subproblems in which the constraints are only of the lower-level type. Inexact resolution of the lower-level constrained subproblems is considered. Global convergence is proved using the constant positive linear dependence constraint qualification. Conditions for boundedness of the penalty parameters are discussed. The resolution of location problems in which many constraints of the lower-level set are nonlinear is addressed, employing the spectral projected gradient method for solving the subproblems. Problems of this type with more than 3 × 10 6 variables and 14 × 10 6 constraints are solved in this way, using moderate computer time. All the codes are available at http://www.ime.usp.br/∼egbirgin/tango/.
Type de document :
Article dans une revue
SIAM Journal on Optimization, Society for Industrial and Applied Mathematics, 2008, <10.1137/060654797>
Liste complète des métadonnées
https://hal.archives-ouvertes.fr/hal-01295437
Contributeur : Mathias Legrand <>
Soumis le : jeudi 31 mars 2016 - 04:42:00
Dernière modification le : jeudi 31 mars 2016 - 09:42:14
Document(s) archivé(s) le : lundi 14 novembre 2016 - 10:28:47
Fichier
optim.pdf
Fichiers produits par l'(les) auteur(s)
Distributed under a Creative Commons Paternité - Partage selon les Conditions Initiales 4.0 International License
Citation
R Andreani, Ernesto Birgin, J. Martinez, M. L. Schuverdt. On Augmented Lagrangian Methods with General Lower-Level Constraints. SIAM Journal on Optimization, Society for Industrial and Applied Mathematics, 2008, <10.1137/060654797>. <hal-01295437>
Métriques
Consultations de
la notice
40
Téléchargements du document
83
