Finite-Time and Fixed-Time Observers Design via Implicit Lyapunov Function - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
— This paper deals with the problem of finite-time and fixed-time observation of linear multiple input multiple output (MIMO) control systems. The nonlinear dynamic observers , which guarantee convergence of the observer states to the original system state in a finite and a fixed (defined a priori) time, are studied. Algorithms for the observers parameters tuning are also developed. The theoretical results are illustrated by numerical examples.
Automatique
ECC16_0408_FI.pdf (465.49 Ko) Télécharger le fichier
hal-01298162 , version 1 (05-04-2016)
  • HAL Id : hal-01298162 , version 1
Francisco Lopez-Ramirez, Andrey Polyakov, Denis Efimov, Wilfrid Perruquetti. Finite-Time and Fixed-Time Observers Design via Implicit Lyapunov Function. European Control Conference 2016, Jun 2016, Aalborg, Denmark. ⟨hal-01298162⟩
265 Consultations
567 Téléchargements
