Characterisation of the Transient Dynamics of a Controlled Separated Flow Using Phase Averaged PIV, International Conference on Instability and Control of Massively Separated Flows ? ICOMASEF, 2013. ,
DOI : 10.1007/978-3-319-06260-0_27
Experimental closed-loop control of a detached boundary layer at high Reynolds number, 10th EUROMECH Fluid Mechanics Conference, 2014. ,
Experimental detection of flow separation over a plain flap by wall shear stress analysis with and without steady blowing, Comptes Rendus M??canique, vol.342, issue.6-7, pp.389-402, 2014. ,
DOI : 10.1016/j.crme.2014.01.013
Experimental closed-loop control of flow separation over a plain flap using slope seeking, Experiments in Fluids, vol.49, issue.7, pp.1-19, 2014. ,
DOI : 10.1007/s00348-014-1797-2
Open and closedloop experiments to identify the separated flow dynamics of a thick turbulent boundary layer, Experiments in Fluids, vol.54, pp.1-22, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00841368
Control of low-speed turbulent separated flow using jet vortex generators, Experiments in Fluids, vol.12, issue.6, pp.394-400, 1992. ,
DOI : 10.1007/BF00193886
Control of turbulent separated flow over a backward-facing step by local forcing Model reduction and control of a cavity-driven separated boundary layer, IUTAM Symposium on Flow Control and MEMS bibtex: akervik model, pp.417-426, 1996. ,
Optimal control of the unsteady Navier-Stokes equations, 2006. ,
Optimal Control of Two- and Three-Dimensional Incompressible Navier???Stokes Flows, Journal of Computational Physics, vol.136, issue.2, pp.231-244, 1997. ,
DOI : 10.1006/jcph.1997.5744
Local exact controllability of the Navier???Stokes system, Local exact controllability of the Navier?Stokes system, pp.1501-1542, 2004. ,
DOI : 10.1016/j.matpur.2004.02.010
Neural-network predictive control for nonlinear dynamic systems with time-delay, IEEE Transactions on Neural Networks, vol.14, issue.2, pp.377-389, 2003. ,
DOI : 10.1109/TNN.2003.809424
Constrained MPC algorithm for uncertain time-varying systems with state-delay, IEEE Transactions on Automatic Control, vol.50, issue.2, pp.257-263, 2005. ,
DOI : 10.1109/TAC.2004.841920
Robust constrained model predictive control using linear matrix inequalities, Automatica, vol.32, issue.10, pp.1361-1379, 1996. ,
DOI : 10.1016/0005-1098(96)00063-5
Stability and stabilization of time-delay systems, 1995. ,
Algorithm 909, ACM Transactions on Mathematical Software, vol.37, issue.4, p.44, 2011. ,
DOI : 10.1145/1916461.1916468
Delay system identification applied to the longitudinal flight of an aircraft through a vertical gust, 2006 14th Mediterranean Conference on Control and Automation, pp.1-6, 2006. ,
DOI : 10.1109/MED.2006.328876
URL : https://hal.archives-ouvertes.fr/inria-00192426
Experimental study of eddy structures in a turbulent boundary layer using particle image velocimetry, Journal of Fluid Mechanics, vol.535, pp.143-188, 2005. ,
DOI : 10.1017/S0022112005004751
URL : https://hal.archives-ouvertes.fr/hal-00072384
System identification -Theory for the User, 1999. ,
NARX modelling of unsteady separation control, Experiments in Fluids, vol.46, issue.1, pp.1-17, 2013. ,
DOI : 10.1007/s00348-012-1445-7
Globalization strategies for??Mesh Adaptive Direct Search, Computational Optimization and Applications, vol.7, issue.1, pp.193-215, 2009. ,
DOI : 10.1007/s10589-009-9266-1
Nonsmooth optimization through Mesh Adaptive Direct Search and Variable Neighborhood Search, Journal of Global Optimization, vol.39, issue.2, pp.299-318, 2007. ,
DOI : 10.1007/s10898-007-9234-1
Mesh Adaptive Direct Search Algorithms for Constrained Optimization, SIAM Journal on Optimization, vol.17, issue.1, pp.188-217, 2006. ,
DOI : 10.1137/040603371
OPTI: Lowering the Barrier Between Open Source Optimizers and the Industrial MATLAB User, Foundations of Computer-Aided Process Operations, 2012. ,
