A review of Gaussian random fields and correlation functions, 1997. ,
A full-field optical method for the experimental analysis of reinforced concrete beams repaired with composites, Composites Part A: Applied Science and Manufacturing, vol.35, issue.7-8, pp.873-884, 2004. ,
DOI : 10.1016/j.compositesa.2004.01.012
Investigation of the grid method for accurate in-plane strain measurement, Measurement Science and Technology, vol.20, issue.9, p.95102, 2009. ,
DOI : 10.1088/0957-0233/20/9/095102
A Procedure for Accurate One-Dimensional Strain Measurement Using the Grid Method, Experimental Mechanics, vol.29, issue.7???8, pp.841-854, 2009. ,
DOI : 10.1007/s11340-008-9203-8
Strain intermittency in shape-memory alloys, Physical Review B, vol.91, issue.17, p.91174111, 2015. ,
DOI : 10.1103/PhysRevB.91.174111
Basics of metrology and introduction to techniques Full-field measurements and identification in solid mechanics, pp.1-29, 2012. ,
Time-frequency analysis, 1995. ,
Geometric phase analysis based on the windowed Fourier transform for the deformation field measurement, Optics & Laser Technology, vol.58, pp.119-127, 2014. ,
DOI : 10.1016/j.optlastec.2013.11.010
Investigation of martensitic microstructures in a monocrystalline Cu???Al???Be shape memory alloy with the grid method and infrared thermography, Mechanics of Materials, vol.45, issue.1, pp.34-51, 2012. ,
DOI : 10.1016/j.mechmat.2011.09.007
Separability, positivity, and minimum uncertainty in time???frequency energy distributions, Journal of Mathematical Physics, vol.39, issue.8, pp.4016-4040, 1998. ,
DOI : 10.1063/1.532483
Anniversary Article: Effect of Sensor Noise on the Resolution and Spatial Resolution of Displacement and Strain Maps Estimated with the Grid Method, Strain, vol.22, issue.1, pp.1-27, 2014. ,
DOI : 10.1111/str.12070
The Grid Method for In-plane Displacement and Strain Measurement: A Review and Analysis, Strain, vol.372, issue.3, 2016. ,
DOI : 10.1111/ext.12162
Studying the Mechanical Behaviour of Asphalt Mixture with the Grid Method, Strain, vol.28, issue.1, pp.1-15, 2013. ,
DOI : 10.1111/str.12006
On the use of windows for harmonic analysis with the discrete Fourier transform, Proceedings of the IEEE, pp.51-83, 1978. ,
DOI : 10.1109/PROC.1978.10837
Radiometric CCD camera calibration and noise estimation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.16, issue.3, pp.267-276, 1994. ,
DOI : 10.1109/34.276126
Linear and quadratic time-frequency signal representations, IEEE Signal Processing Magazine, vol.9, issue.2, pp.21-67, 1992. ,
DOI : 10.1109/79.127284
Comparison of Fourier transform, windowed Fourier transform, and wavelet transform methods for phase extraction from a single fringe pattern in fringe projection profilometry, Optics and Lasers in Engineering, vol.48, issue.2, pp.141-148, 2010. ,
DOI : 10.1016/j.optlaseng.2009.04.003
Automated fringe pattern analysis in experimental mechanics: a review, The Journal of Strain Analysis for Engineering Design, vol.23, issue.2, pp.105-125, 1998. ,
DOI : 10.1243/0309324981512850
Windowed Fourier transform for fringe pattern analysis, Applied Optics, vol.43, issue.13, pp.2695-2702, 2004. ,
DOI : 10.1364/AO.43.002695
Two-dimensional windowed Fourier transform for fringe pattern analysis: Principles, applications and implementations, Optics and Lasers in Engineering, vol.45, issue.2, pp.304-317, 2007. ,
DOI : 10.1016/j.optlaseng.2005.10.012
A wavelet tour of signal processing, 1999. ,
Grid Method, Moir?? and Deflectometry, Full-field Measurements and Identification in Solid Mechanics, pp.61-89, 2012. ,
DOI : 10.1002/9781118578469.ch3
On the realization of microscopic grids for local strain measurement by direct interferometric photolithography, Optics and Lasers in Engineering, vol.45, issue.12, pp.1131-1147, 2007. ,
DOI : 10.1016/j.optlaseng.2007.06.009
Image restoration with noise suppression using a multiresolution support, Astronomy and astrophysics, vol.112, pp.179-189, 1995. ,
A real time 3D signal analysis/synthesis tool based on the short time Fourier transform, 2004. ,
Beyond Hopkinson's bar, Philosophical Transactions of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.49, issue.5232, p.20130195, 2014. ,
DOI : 10.1126/science.7569924
Characterization of a cracked specimen with full-field measurements: direct determination of the crack tip and energy release rate calculation, International Journal of Fracture, vol.42, issue.4, pp.109-121, 2014. ,
DOI : 10.1007/s10704-013-9921-5
Using Sampling Moir?? to Extract Displacement Information from X-Ray Images of Molten Salt Batteries, Conference proceedings of the Society for Experimental Mechanics series, pp.331-336, 2014. ,
DOI : 10.1007/978-3-319-06986-9_38
Noncontact Deflection Distribution Measurement for Large-Scale Structures by Advanced Image Processing Technique, MATERIALS TRANSACTIONS, vol.53, issue.2, pp.323-329, 2012. ,
DOI : 10.2320/matertrans.I-M2011852
Determining displacement and strain maps immune from aliasing effect with the grid method, Optics and Lasers in Engineering, vol.86, 2016. ,
DOI : 10.1016/j.optlaseng.2016.06.010
URL : https://hal.archives-ouvertes.fr/hal-01352868
Towards deconvolution to enhance the grid method for in-plane strain measurement, Inverse Problems and Imaging, vol.8, issue.1, pp.259-291, 2014. ,
DOI : 10.3934/ipi.2014.8.259
URL : https://hal.archives-ouvertes.fr/hal-00749804
On noise reduction in strain maps obtained with the grid method by averaging images affected by vibrations, Optics and Lasers in Engineering, vol.66, pp.210-222, 2015. ,
DOI : 10.1016/j.optlaseng.2014.09.013
URL : https://hal.archives-ouvertes.fr/hal-01075764
Design of algorithms for phase measurements by the use of phase stepping, Applied Optics, vol.35, issue.1, pp.51-60, 1996. ,
DOI : 10.1364/AO.35.000051
Additive noise effect in digital phase detection, Applied Optics, vol.36, issue.1, pp.271-276, 1997. ,
DOI : 10.1364/AO.36.000271
Photomechanics, volume 77 of Topics in Applied Physics, chapter Fringe analysis, pp.55-102, 2000. ,
A Self Adaptive Global Digital Image Correlation Algorithm, Experimental Mechanics, vol.48, issue.6, pp.361-378, 2015. ,
DOI : 10.1007/s11340-014-9946-3
