Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Abstract : In this paper we examine an extension of the core concept for the 0/1 Multidimensional Knapsack Problem (MKP) towards general 0/1 Integer Programming (IP) by allowing negative profits, weights and capacities. The core concept provides opportunities for heuristically solving the MKP, achieving higher quality solutions and shorter run-times than general IP methods. We provide the theoretical foundations of the extended core concept and further provide computational experiments showing that we can achieve similar computational behavior for extended MKP instances with negative weights, profits and capacities.
https://hal.inria.fr/hal-01299754 Contributor : Jakob PuchingerConnect in order to contact the contributor Submitted on : Friday, April 8, 2016 - 12:05:50 PM Last modification on : Sunday, June 26, 2022 - 2:26:04 AM Long-term archiving on: : Monday, November 14, 2016 - 11:06:04 PM
Sam Huston, Jakob Puchinger, Peter J Stuckey. The Core Concept for 0/1 Integer Programming. Fourteenth Computing: The Australasian Theory Symposium (CATS2008), Jan 2008, Wollongong, Australia. ⟨hal-01299754⟩
