Gene selection for cancer classification using support vector machines SVM-RFE with relevancy and redundancy criteria for gene selection, Machine Learning, pp.242-252, 2002. ,
Toward integrating feature selection algorithms for classification and clustering Uci machine learning repository, IEEE Trans. Knowl. Data Eng, vol.17, issue.4, pp.491-502, 1920. ,
Feature selection: evaluation, application, and small sample performance, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.19, issue.2, pp.153-158, 1997. ,
DOI : 10.1109/34.574797
Memetic Feature Selection: Benchmarking Hybridization Schemata, HAIS(1), pp.351-358, 2010. ,
DOI : 10.1016/j.patrec.2008.11.012
SVM-Based Local Search for Gene Selection and Classification of Microarray Data, pp.499-508, 2008. ,
DOI : 10.1007/978-3-540-70600-7_39
The nature of statistical learning theory SUPPLEMENTARY INFORMATION multi-class cancer diagnosis using tumor gene expression signatures, 1995. ,
An introduction to variable and feature selection, J. Mach. Learn. Res, vol.3, pp.1157-1182, 2003. ,
Privacy Preserving RFE-SVM for Distributed Gene Selection, IJCSI, pp.154-159, 2012. ,
Improving the performance of SVM- RFE to select genes in microarray data. [17] Malik Yousef ,
An accelerated procedure for recursive feature ranking on microarray data, Neural Networks, vol.16, issue.5-6, pp.5-6, 2003. ,
DOI : 10.1016/S0893-6080(03)00103-5
Development of twostage SVM-RFE gene selection strategy for microarray expression data analysis SVM-RFE with relevancy and redundancy criteria for gene selection, IEEE/ACM Trans. Comput. Biology Bioinform, vol.420, issue.4774, pp.365-381, 2007. ,
NP-completeness of searches for smallest possible feature sets, 1994. ,
The k-Feature Set problem is W[2]-complete, Journal of Computer and System Sciences, vol.67, issue.4, pp.686-690, 2003. ,
DOI : 10.1016/S0022-0000(03)00081-3
Méthodes heuristiques pour l'optimisation combinatoire et l'affectation sous contraintes ,
Data mining : practical machine learning tools and techniques with Java implementations, 2000. ,
