IP integration methodology for SoC design, Proceedings. The 16th International Conference on Microelectronics, 2004. ICM 2004., 2004. ,
DOI : 10.1109/ICM.2004.1434582
URL : https://hal.archives-ouvertes.fr/hal-00077856
Platform-based design from parallel C specifications, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.24, issue.12, pp.1811-1826, 2005. ,
DOI : 10.1109/TCAD.2005.852431
Compilation of polychronous dataflow equations, Synthesis of Embedded Software Springer, 2010. ,
Compiling Dataflow Program for digital signal processing, 1997. ,
Synchronous Processor synthesis for Latency Insensitive Systems, Proceedings of the Design, Automation and Test in Europe Conference and Exhibition (DATE'02), 2005. ,
GAUT, High Level Synthesis for Digital Signal Processors: User's Manual, version 4.1 " Laboratoire d'Electronique des Systèmes Temps RéelLESTER ,
Asynchronous wrapper for heterogeneous systems, Proceedings International Conference on Computer Design VLSI in Computers and Processors, 1997. ,
DOI : 10.1109/ICCD.1997.628884
Theory of latency-insensitive design, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.20, issue.9, 2001. ,
DOI : 10.1109/43.945302
Adaptive Latency-Insensitive, Globally Asynchronous, Locally Synchronous Design and Test, IEEE Design & Test of Computers, 2007. ,
Intellectual Property (IP) Integration Approach for Data-Flow parallel embedded Systems, Proceedings of Fourth International IEEE EAI Conference on e-Infrastructure and e-Services for Developing Countries num, 2012. ,
Modeling and scheduling Parallel DataFlow systems using structured systems of Recurrence Equations, Procedings of the 15th IEEE International Conference on Aplication-Specific system, Architectures and Processors, 2004. ,
Synthèse automatique d'interfaces de communication matérielles pour la conception d'applications du domaine du traitement du signal, Thèse, 2007. ,
A design methodology for space-time adapter, Proceedings of the 17th great lakes symposium on Great lakes symposium on VLSI , GLSVLSI '07, 2007. ,
DOI : 10.1145/1228784.1228868
URL : https://hal.archives-ouvertes.fr/hal-00153789
The Next Generation of CDMA Technologies, 2007. ,
DOI : 10.1002/9780470022962
Design and implementation of a multidimensional synchronous dataflow environment, Proceedings of 1994 28th Asilomar Conference on Signals, Systems and Computers, p.97 ,
DOI : 10.1109/ACSSC.1994.471507
A formal method for hardware IP design and integration under I/O and timing constraints, ACM Transactions on Embedded Computing Systems, vol.5, issue.1, pp.1-29, 2006. ,
DOI : 10.1145/1132357.1132359
URL : https://hal.archives-ouvertes.fr/hal-00077729
The Signal Synchronous Multi-clock Approach to the Design of Distributed Embedded Systems, IEEE Transactions on Parallel and Distributed Systems, 2010. ,
Electronic System-Level Synthesis Methodologies, IEEE Transactions on Computer-Aided Design of Integrated Circuits and Systems, vol.28, issue.10, 2009. ,
DOI : 10.1109/TCAD.2009.2026356
Stream Programming on General-Purpose Processors, 38th Annual IEEE/ACM International Symposium on Microarchitecture (MICRO'05), 2005. ,
DOI : 10.1109/MICRO.2005.32
Streamware: Programming General-Purpose Multicore Processors Using Streams " ASP- LOS'08, 2008. ,
SPARK: A Parallelizing Approach to the High-Level Synthesis of Digital Circuits, Kluwer Academic, 2004. ,
Imagine: media processing with streams, IEEE Micro, vol.21, issue.2, pp.35-46, 2001. ,
DOI : 10.1109/40.918001
Static Scheduling of Synchronous DataFlow Programs for Digital Signal Processing, IEEE Transactions of Computers, pp.36-135, 1987. ,
Cyber Physical Systems: Design Challenges, 2008 11th IEEE International Symposium on Object and Component-Oriented Real-Time Distributed Computing (ISORC), 2008. ,
DOI : 10.1109/ISORC.2008.25
Introduction to Embedded Systems -A Cyber-Physical Systems Approach, 2011. ,
Hierarchical and Multipleclock Domain High-Level Synthesis for Low-Power Design on FPGA, Proceedings of FPL, 2010. ,
IRISA, Université de Rennes I " , Définition de ALPHA: un langage pour la programmation systolique, 1989. ,
Multidimensional synchronous dataflow, IEEE Transactions on Signal Processing, vol.50, issue.8, pp.2064-2079, 2002. ,
DOI : 10.1109/TSP.2002.800830
Automated Integration of Dedicated Hardwired IP Cores in Heterogeneous MPSoCs Designed with ESPAM, EURASIP Journal on Embedded Systems, vol.1132, issue.1, p.15, 2008. ,
DOI : 10.1109/TVLSI.2006.878259
A comparison of Synchronous and Cyclo-Static Dataflow, Proceeding of the IEEE Asilomar conference on Signal, Systems, and Computers, 1995. ,
Structured Scheduling of Recurrence Equations: Theory and Practice, 2001. ,
DOI : 10.1007/3-540-45874-3_7
Efficient hardware implementation of data-flow parallel embedded systems, 2012 International Conference on Embedded Computer Systems (SAMOS), pp.364-371, 2012. ,
DOI : 10.1109/SAMOS.2012.6404202
GAUT: A High Level Synthesis Tool Dedicated to Real Time Signal Processing Application, European Design Automation Conference, 2000. ,
Generalized latency-insensitive systems for single-clock and multi-clock architectures, Proceedings Design, Automation and Test in Europe Conference and Exhibition, 2004. ,
DOI : 10.1109/DATE.2004.1269025
Multi-Clock Latency-Insensitive Architecture and Wrapper synthesis, Electronic Notes in Theoretical Computer Science, 2006. ,
Affine transformations in SIGNAL and their application in the spécification and validation of real-time guif, LNCS 1231, 1997. ,
System Design Using Kahn Process Networks: The Compaan/Laura Approach, DATE'04: Proceedings of the Conference on Design, Automation and Test in Europe, p.10340, 2004. ,
StreamIt: A Language for Streaming Applications, 11th conf. Compiled Construction, num. LNCS 2304, pp.179-196, 2002. ,
DOI : 10.1007/3-540-45937-5_14
