Development of new high-throughput screening method to compare and to detect efficient catalysts for adhesive materials - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Adhesion and Adhesives Année : 2016
Organotin compounds particularly dibutyltin dilaurate, are commonly used as catalysts in coatings or adhesive materials to crosslink silyl modified polymers. However, environmental concerns should lead before 2020 to ban organotin compounds due to their high toxicity. Thus new catalysts must be developed. According to the different types of catalytic systems, i.e. acid, basic or metal containing catalysts, a large variety of candidates should be tested. Thus a high-throughput screening (HTS) method could be an interesting tool for the detection of new efficient catalysts to substitute organotin compounds. We report a global HTS method, compatible with organic amino or acid catalysts libraries, as well as with metal-containing libraries
Polymères Catalyse
Development of new high-throughput screening.pdf (577.1 Ko) Télécharger le fichier
hal-01300878 , version 1 (27-05-2016)
Boris Colin, Olivier Lavastre, Stéphane Fouquay, Guillaume Michaud, Frédéric Simon, et al.. Development of new high-throughput screening method to compare and to detect efficient catalysts for adhesive materials. International Journal of Adhesion and Adhesives, 2016, 68, pp.47-53. ⟨10.1016/j.ijadhadh.2016.02.002⟩. ⟨hal-01300878⟩
111 Consultations
215 Téléchargements
