New interface
Reports (Research report)
High-Level Synthesis of Pipelined FSM from Loop Nests
Christophe Alias 1, 2, * Fabrice Rastello 3 Alexandru Plesco 4
* Corresponding author
2 ROMA - Optimisation des ressources : modèles, algorithmes et ordonnancement
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
3 CORSE - Compiler Optimization and Run-time Systems
Inria Grenoble - Rhône-Alpes, LIG - Laboratoire d'Informatique de Grenoble
Abstract : Embedded systems raise many challenges in power, space and speed efficiency. The current trend is to build heterogeneous systems on a chip with specialized processors and hardware accelerators. Generating an hardware accelerator from a computational kernel requires a deep reorganization of the code and the data. Typically, parallelism and memory bandwidth are met thanks to fine-grain loop transformations. Unfortunately, the resulting control automaton is often very complex and eventually bound the circuit frequency, which limits the benefits of the optimization. This is a major lock, which strongly limits the power of the code optimizations applicable by high-level synthesis tools. In this report, we propose an architecture of control automaton and an algorithm of high-level synthesis which translates efficiently the control required by fine-grain loop optimizations. Unlike the previous approaches, our control automaton can be pipelined at will, without any restriction. Hence, the frequency of the automaton can be as high as possible. Experimental results on FPGA confirms that our control circuit can reach a high frequency with a reasonable resource consumption.
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/hal-01301334
Contributor : Christophe Alias Connect in order to contact the contributor
Submitted on : Friday, August 19, 2016 - 2:18:33 PM
Last modification on : Wednesday, October 26, 2022 - 8:15:16 AM
Long-term archiving on: : Sunday, November 20, 2016 - 10:43:48 AM
File
RR-8900.pdf
Identifiers
  • HAL Id : hal-01301334, version 2
Citation
Christophe Alias, Fabrice Rastello, Alexandru Plesco. High-Level Synthesis of Pipelined FSM from Loop Nests. [Research Report] 8900, INRIA. 2016, pp.18. ⟨hal-01301334v2⟩
Share
Metrics
Record views
273
Files downloads
218
