Early Nordic Compilers and Autocodes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Peter Sestoft
  • Fonction : Auteur
  • PersonId : 980866
The early development of compilers for high-level programming languages, and of so-called autocoding systems, is well documented at the international level but not as regards the Nordic countries.The goal of this paper is to provide a survey of compiler and autocode development in the Nordic countries in the early years, roughly 1953 to 1965, and to relate it to international developments. We also touch on some of the historical societal context.
336948_1_En_36_Chapter.pdf (4 Ko) Télécharger le fichier
hal-01301428 , version 1 (12-04-2016)
Paternité
Peter Sestoft. Early Nordic Compilers and Autocodes. 4th History of Nordic Computing (HiNC4), Aug 2014, Copenhagen, Denmark. pp.350-366, ⟨10.1007/978-3-319-17145-6_36⟩. ⟨hal-01301428⟩
41 Consultations
225 Téléchargements
