New interface
Conference papers
Diagnosability of Repairable Faults
Eric Fabre 1 Loïc Hélouët 1 Engel Lefaucheux 2, 1, 3 Hervé Marchand 1
1 SUMO - SUpervision of large MOdular and distributed systems
Inria Rennes – Bretagne Atlantique , IRISA-D4 - LANGAGE ET GÉNIE LOGICIEL
2 MEXICO - Modeling and Exploitation of Interaction and Concurrency
LSV - Laboratoire Spécification et Vérification [Cachan], Inria Saclay - Ile de France
Abstract : The diagnosis problem for discrete event systems consists in deciding whether some fault event occurred or not in the system, given partial observations on the run of that system. Diagnosability checks whether a correct diagnosis can be issued in bounded time after a fault, for all faulty runs of that system. This problem appeared two decades ago and numerous facets of it have been explored, mostly for permanent faults. It is known for example that diagnosability of a system can be checked in polynomial time, while the construction of a diagnoser is exponential. The present paper examines the case of transient faults, that can appear and be repaired. Diagnosability in this setting means that the occurrence of a fault should always be detected in bounded time, but also before the fault is repaired. Checking this notion of diagnosability is proved to be PSPACE-complete. It is also shown that faults can be reliably counted provided the system is diagnosable for faults and for repairs.
Document type :
Conference papers
Complete list of metadata
Cited literature [6 references]  Display  Hide  Download
https://hal.inria.fr/hal-01302562
Contributor : Hervé Marchand Connect in order to contact the contributor
Submitted on : Thursday, April 14, 2016 - 3:36:26 PM
Last modification on : Saturday, June 25, 2022 - 7:42:50 PM
Long-term archiving on: : Friday, July 15, 2016 - 1:11:18 PM
File
repairdiag.pdf
Identifiers
  • HAL Id : hal-01302562, version 1
Citation
Eric Fabre, Loïc Hélouët, Engel Lefaucheux, Hervé Marchand. Diagnosability of Repairable Faults. 13th International Workshop on Discrete Event Systems, 2016, Xi'an, China. pp.256-262. ⟨hal-01302562⟩
Share
Metrics
Record views
506
Files downloads
168
