A continuation-passing-style interpretation of simply-typed call-by-need λ-calculus with control within System F - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
Ariola et al defined a call-by-need λ-calculi with control, together with a sequent calculus presentation of it, and a mechanically generated continuation-passing-style transformation simulating the reduction. We present here a simply-typed version of this calculus and shows that it maps to System F through the continuation-passing-style transformation. This implies in particular the normaliza-tion of this simply-typed call-by-need calculus with control. Incidentally, we treat bound variables for the continuation-passing-style transformation in a precise way using indices rather than up to α-conversion, what makes it directly implementable.
cbncps.pdf (164.3 Ko) Télécharger le fichier
hal-01302696 , version 1 (14-04-2016)
hal-01302696 , version 2 (25-05-2016)
Paternité
  • HAL Id : hal-01302696 , version 1
Hugo Herbelin, Étienne Miquey. A continuation-passing-style interpretation of simply-typed call-by-need λ-calculus with control within System F. 2016. ⟨hal-01302696v1⟩
616 Consultations
100 Téléchargements
