Intra-operative 3D micro-coil imaging using subsampled tomographic acquisition patterns on a biplane C-arm system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The restriction of CBCT to micro-coil imaging allows for integrating key a priori knowledge that a coil is a high-density spatially sparse curvilinear structure. In this paper, we investigate acquisition patterns specifically designed for biplane systems allowing a faster workflow and reduced dose. Each pattern is a subsampling of a standard tomographic acquisition reconstructed with an 1-constrained algorithm to promote sparsity together with diffusion filters that promote the curvilinear nature of the coil. Three tensor-based 3D diffusion filters are investigated. Quantitative and qualitative results are provided for one coil and four patients datasets. They show how the reconstruction performs according to the selected acquisition pattern (uniform versus non-uniform subsampling), the quantity of missing information and the selected diffusion filter. We observed a systematically better recovery of the coil in reconstructions obtained using a uniform subsampling pattern but at the cost of being systematically noisier than those obtained with a non-uniform subsampling pattern. Diffusion filtering significantly reduced this structural noise.
ctmeeting_2016_charlotte_delmas_final_submisson.pdf (1.06 Mo) Télécharger le fichier
hal-01303153 , version 1 (16-04-2016)
  • HAL Id : hal-01303153 , version 1
Charlotte Delmas, Cyril Riddell, Yves Trousset, Erwan Kerrien, Marie-Odile Berger, et al.. Intra-operative 3D micro-coil imaging using subsampled tomographic acquisition patterns on a biplane C-arm system. Proceedings of the 4th International Conference on Image Formation in X-Ray Computed Tomography (CT meeting'16), Jul 2016, Bamberg, Germany. ⟨hal-01303153⟩
194 Consultations
105 Téléchargements
