New interface
Journal articles
The Maxwell-Stefan diffusion limit for a kinetic model of mixtures with general cross sections
Abstract : In this article, we derive the Maxwell-Stefan formalism from the Boltzmann equation for mixtures for general cross-sections. The derivation uses the Hilbert asymptotic method for systems at low Knudsen and Mach numbers. We also formally prove that the Maxwell-Stefan coecients can be linked to the direct linearized Boltzmann operator for mixtures. That allows to compute the values of the Maxwell-Stefan diusion coecients with explicit and simple formulae with respect to the cross-sections. We also justify the specic ansatz we use thanks to the so-called moment method.
Document type :
Journal articles
Complete list of metadata
Cited literature [46 references]  Display  Hide  Download
https://hal.inria.fr/hal-01303312
Contributor : Laurent Boudin Connect in order to contact the contributor
Submitted on : Sunday, April 17, 2016 - 9:45:08 PM
Last modification on : Friday, July 8, 2022 - 10:05:54 AM
Long-term archiving on: : Monday, July 18, 2016 - 11:00:16 AM
File
msbgp.pdf
Identifiers
Citation
Laurent Boudin, Bérénice Grec, Vincent Pavan. The Maxwell-Stefan diffusion limit for a kinetic model of mixtures with general cross sections. Nonlinear Analysis: Theory, Methods and Applications, 2017, 159, pp.40-61. ⟨10.1016/j.na.2017.01.010⟩. ⟨hal-01303312⟩
Share
Metrics
Record views
397
Files downloads
610
