Using Plug&Play Control for stable ACC-CACC system transitions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
— This paper examines the already commercially available Adaptive Cruise Controller (ACC) system, and its evolution by adding vehicle-to-vehicle communications: the cooperative ACC (CACC) version. The transition between ACC and CACC controllers will be done through the new control technique called Plug&Play. This technique is able to deal with living systems and the changes in its sensors and actuators to preserve the system stable. The aim is to ensure the system stability during transitions between controllers when the vehicle-to-vehicle communication link is changing from unavailable to available or vice versa.
iv_16_Using_P&P_for stable_ACC_CACC_controller_transitions.pdf (656.42 Ko) Télécharger le fichier
hal-01304542 , version 1 (19-04-2016)
Francisco Navas, Vicente Milanés, Fawzi Nashashibi. Using Plug&Play Control for stable ACC-CACC system transitions. Intelligent Vehicles Symposium 2016, Jun 2016, Gothemburg, Sweden. ⟨10.1109/IVS.2016.7535464⟩. ⟨hal-01304542⟩
Collections
INRIA INRIA2
144 Consultations
333 Téléchargements
