New interface
Conference papers
Toward Ultrasound-based Visual Servoing using Shearlet Coefficients
Lesley-Ann Duflot 1, 2 Alexandre Krupa 1 Brahim Tamadazte 2 Nicolas Andreff 2
1 Lagadic - Visual servoing in robotics, computer vision, and augmented reality
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Rennes – Bretagne Atlantique , IRISA-D5 - SIGNAUX ET IMAGES NUMÉRIQUES, ROBOTIQUE
Abstract : This paper deals with the development of a new 6 degrees-of-freedom (DOF) vision-based controller for robot-assisted medical applications. The main objective is to use visual information extracted from Ultrasounds (US) images to control an US probe held by the robot. Instead of the conventional use of visual features e.g., geometric features (points, lines, moments, etc.) in the visual control law design, the described method use the shearlet coefficients. More precisely, the time-variation of the coarsest level of shearlet decomposition coefficients are linked to the US probe (respectively to the robot) spatial velocity and then related to the task-function control law. The proposed control law was experimentally tested and validated using a realistic abdominal phantom. The obtained results demonstrated promising performances in terms of accuracy, repeatability, robustness and convergence behavior.
Document type :
Conference papers
Complete list of metadata
Cited literature [15 references]  Display  Hide  Download
https://hal.inria.fr/hal-01304753
Contributor : Eric Marchand Connect in order to contact the contributor
Submitted on : Wednesday, April 20, 2016 - 11:57:28 AM
Last modification on : Friday, January 21, 2022 - 3:09:02 AM
Long-term archiving on: : Tuesday, November 15, 2016 - 7:07:04 AM
File
ICRA2016duflot.pdf
Identifiers
  • HAL Id : hal-01304753, version 1
Citation
Lesley-Ann Duflot, Alexandre Krupa, Brahim Tamadazte, Nicolas Andreff. Toward Ultrasound-based Visual Servoing using Shearlet Coefficients. IEEE Int. Conf. on Robotics and Automation, ICRA'16, May 2016, Stockholm, Sweden. ⟨hal-01304753⟩
Share
Metrics
Record views
311
Files downloads
132
