Software Component Design with the B Method — A Formalization in Isabelle/HOL - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a formal development of an Isabelle/HOL theory for the behavioral aspects of artifacts produced in the design of software components with the B method. We first provide a formaliza-tion of semantic objects such as labelled transition systems and notions of behavior and simulation. We define an interpretation of the B method using such concepts. We also address the issue of component composition in the B method.
paper.pdf (288.59 Ko) Télécharger le fichier
hal-01305026 , version 1 (20-04-2016)
David Déharbe, Stephan Merz. Software Component Design with the B Method — A Formalization in Isabelle/HOL. Formal Aspects of Component Software - 12th International Conference, FACS 2015, Oct 2015, Niterói, Brazil. pp.31-47, ⟨10.1007/978-3-319-28934-2_2⟩. ⟨hal-01305026⟩
278 Consultations
338 Téléchargements
