SK ID h ) · t (A ?1 ) (by quering the Extract algorithm on the h identities ID j for j ? {1, recover the secret key vector (r 1 ,
Identity-Based Encryption from the Weil Pairing, SIAM J. Comput, vol.32, issue.3, pp.586-615, 2003. ,
On Parity Check (0, 1)-Matrix over Z p, Proceedings of the Twenty-Second Annual ACM-SIAM Symposium on Discrete Algorithms, pp.1383-1394, 2011. ,
Random Oracles are Practical: A Paradigm for Designing Efficient Protocols, Proceedings of the First ACM Conference on Computer and Communications, pp.62-73, 1993. ,
An Identity Based Encryption Scheme Based on Quadratic Residues, Cryptography and Coding, 8th IMA International Conference, vol.2260, pp.360-363, 2001. ,
Trapdoors for hard lattices and new cryptographic constructions, Proceedings of the 40th Annual ACM Symposium on Theory of Computing, pp.197-206, 2008. ,
Über eine Anzahlbestimmung und eine damit zusammenhängende Reihe, J. Reine und Angewandte Math, vol.111, pp.87-88, 1893. ,
Identity-Based Cryptosystems and Signature Schemes, Advances in Cryptology -Crypto, Lect. Notes Comput. Sci, vol.84, pp.47-53, 1985. ,
A strong provably secure IBE scheme without bilinear map, J. Comput. Syst. Sci, vol.81, pp.125-131, 2015. ,
