SPAC:A Synergistic Prefetcher Aggressiveness Controller for Multi-core Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Computers Année : 2016
Biswabandan Panda
  • Fonction : Auteur
  • PersonId : 981496
—In multi-core systems, prefetch requests of one core interfere with the demand and prefetch requests of other cores at the shared resources, which causes prefetcher-caused interference. Prefetcher aggressiveness controllers play an important role in minimizing the prefetcher-caused interference. State-of-the-art controllers such as hierarchical prefetcher aggressiveness control (HPAC) select appropriate throttling levels that can lead to improvement in system performance. However, HPAC does not consider the interactions between the throttling decisions of multiple prefetchers, and loses opportunity to improve system performance further. For multi-core systems, state-of-the-art prefetcher aggressiveness controllers controls the aggressiveness based on prefetch metrics such as accuracy, bandwidth consumption and cache pollution. We propose a synergistic prefetcher aggressiveness controller (SPAC), which explores the interactions between the throttling decisions of prefetchers, and throttles the prefetchers based on the improvement in fair-speedup of multi-core systems.
SPAC.pdf (1.65 Mo) Télécharger le fichier
hal-01307538 , version 1 (26-04-2016)
hal-01307538 , version 2 (29-08-2016)
Biswabandan Panda. SPAC:A Synergistic Prefetcher Aggressiveness Controller for Multi-core Systems. IEEE Transactions on Computers, 2016, ⟨10.1109/TC.2016.2547392⟩. ⟨hal-01307538v1⟩
201 Consultations
425 Téléchargements
