Arbogast: Higher order AD for special functions with Modular C - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2017
Arbogast : DA d’ordre élevé avec Modular C pour des fonctions spéciales
This high-level toolbox for the calculus with Taylor polynomials is named after L.F.A.~Arbogast (1759--1803), a French mathematician from Strasbourg (Alsace), for his pioneering work in derivation calculus. ``Arbogast'' is based on a well-defined extension of the C programming language, Modular C, and places itself between tools that proceed by operator overloading on one side and by rewriting, on the other. The approach is best described as contextualization of C code because it permits the programmer to place his code in different contexts -- usual math or AD -- to reinterpret it as a usual C function or as a differential operator. Because of the type generic features of modern C, all specializations can be delegated to the compiler. The HOAD with \texttt{arbogast} is exemplified on families of functions of mathematical physics and on models for complex dielectric functions used in optics.
RR-8907.pdf (728.64 Ko) Télécharger le fichier
hal-01307750 , version 1 (26-04-2016)
hal-01307750 , version 2 (03-02-2017)
hal-01307750 , version 3 (05-08-2017)
hal-01307750 , version 4 (11-01-2018)
Paternité - Pas d'utilisation commerciale - Pas de modification
  • HAL Id : hal-01307750 , version 1
Isabelle Charpentier, Jens Gustedt. Arbogast: Higher order AD for special functions with Modular C. [Research Report] 8907, Inria Nancy - Grand Est (Villers-lès-Nancy, France). 2017, pp.20. ⟨hal-01307750v1⟩
466 Consultations
588 Téléchargements
