Du calcul des dérivations, 1800. ,
Arbogast, de l'Institut national de France, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01326311
Arbogast ? Origine d'un outil de dérivation automatique, 2016. ,
The curious history of fa di brunos formula, Amer. Math. Monthly, vol.109, pp.217-234, 2002. ,
Prehistory of Fa???????? di Bruno's Formula, The American Mathematical Monthly, vol.112, issue.2, pp.119-130, 2005. ,
DOI : 10.2307/30037410
Evaluating Derivatives: Principles and Techniques of Algorithmic Differentiation, Society for Industrial Mathematics, 2008. ,
DOI : 10.1137/1.9780898717761
Reverse accumulation and attractive fixed points, Optimization Methods and Software, vol.88, issue.4, pp.311-326, 1994. ,
DOI : 10.1080/10556789208805503
On higher-order differentiation in nonlinear mechanics, Optimization Methods and Software, vol.5, issue.2, pp.221-232, 2012. ,
DOI : 10.1145/355586.364791
Towards a full higher-order AD continuation and bifurcation framework, Optim. Method. Softw, p.2017 ,
Fast higher-order derivative tensors with Rapsodia, Optimization Methods and Software, vol.24, issue.1, pp.1-14, 2009. ,
DOI : 10.1080/10556780802413769
ADIC ? An extensible automatic differentiation tool for ANSI-C. Software?Practice and Experience, pp.1427-1456, 1997. ,
Algorithms and design for a second-order automatic differentiation module, Proceedings of the 1997 international symposium on Symbolic and algebraic computation , ISSAC '97, pp.149-155, 1997. ,
DOI : 10.1145/258726.258770
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.55.8337
Handbook of Mathematical Functions with Formulas, Graphs, and Mathematical Tables, 1964. ,
Evaluating higher derivative tensors by forward propagation of univariate Taylor series, Mathematics of Computation, vol.69, issue.231, pp.1117-1130, 2000. ,
DOI : 10.1090/S0025-5718-00-01120-0
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.109.7883
Organization of computer systems ? the fixed plus variable structure computer, Proc. Western Joint Comput. Conf, pp.33-40, 1960. ,
A new method of solving numerical equations of all orders, by continuous approximation. Philosophical Transactions, Royal Society of London, pp.308-335, 1819. ,
Multiplication of multidigit numbers on automata, Sov. Phys. Dokl, vol.7, p.595596, 1963. ,
Higher-order automatic differentiation of mathematical functions, Computer Physics Communications, vol.189, pp.66-71, 2015. ,
DOI : 10.1016/j.cpc.2014.12.010
Optimized higher-order automatic differentiation for the Faddeeva function, Computer Physics Communications, vol.205, 2016. ,
DOI : 10.1016/j.cpc.2016.04.009
Efficient Higher-Order Derivatives of the Hypergeometric Function, Advances in Automatic Differentiation, pp.127-137, 2008. ,
DOI : 10.1007/978-3-540-68942-3_12
Calculation of modes in an optical fiber using the finite element method and EISPACK. The Bell System Technical Journal, pp.2663-2694, 1983. ,
Eigenvalue Problems in Fiber Optic Design, SIAM Journal on Matrix Analysis and Applications, vol.28, issue.1, pp.105-117, 2006. ,
DOI : 10.1137/S0895479803432708
A generic approach for the solution of nonlinear residual equations. Part II: Homotopy and complex nonlinear eigenvalue method, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.49-52, pp.3999-4004, 2009. ,
DOI : 10.1016/j.cma.2009.09.015
Modern Map Methods in Particle Beam Physics, 1999. ,
COSY INFINITY version 9. Nuclear Instruments and Methods in Physics Research, Section A: Accelerators, Spectrometers, Detectors and Associated Equipment, pp.346-350, 2006. ,
DOI : 10.1016/j.nima.2005.11.109
Calculating Dispersion Derivatives in Fiber-Optic Design, Journal of Lightwave Technology, vol.25, issue.3, pp.811-819, 2007. ,
DOI : 10.1109/JLT.2006.889648
Efficient calculation of higher-order optical waveguide dispersion, Opt. Express, vol.18, pp.19522-19531, 2010. ,
Designing Optical Fibers: Fitting the Derivatives of a Nonlinear Pde-Eigenvalue Problem, American Journal of Computational Mathematics, vol.02, issue.04, pp.2321-330, 2012. ,
DOI : 10.4236/ajcm.2012.24044
Zur Erkl??rung der abnormen Farbenfolge im Spectrum einiger Substanzen, Annalen der Physik und Chemie, vol.219, issue.6, pp.272-282, 1871. ,
DOI : 10.1002/andp.18712190612
Optical Properties of Ag and Cu, Physical Review, vol.76, issue.4, pp.1622-1629, 1962. ,
DOI : 10.1088/0370-1328/76/5/301
Optical properties of metallic films for vertical-cavity optoelectronic devices, Applied Optics, vol.37, issue.22, pp.5271-5283, 1998. ,
DOI : 10.1364/AO.37.005271
Automatic differentiation: Origin and references, 2002. ,
