Models and Algorithms for Intermodal Transportation and Equipment Selection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study a cement transportation problem with asset-management (equipment selection) for strategic planning scenarios involving multiple forms of transportation and network expansion. A deterministic mixed integer programming approach is difficult due to the underlying capacitated multi-commodity network flow model and the need to consider a time-space network to ensure operational feasibility. Considering uncertain aspects is also difficult but important. In this paper we propose three approaches: solve a deterministic mixed integer program optimally; solve stochastic programs to obtain robust bounds on the solution; and, study alternative solutions to obtain their optimal cost vectors using inverse programming.
OR2011.pdf (54.81 Ko) Télécharger le fichier
hal-01307975 , version 1 (27-04-2016)
Christina Burt, Jakob Puchinger. Models and Algorithms for Intermodal Transportation and Equipment Selection. International Conference on Operations Research (OR 2011), Aug 2011, Zurich, Switzerland. ⟨10.1007/978-3-642-29210-1_49⟩. ⟨hal-01307975⟩
63 Consultations
151 Téléchargements
