Automatic generation of hardware FIR filters from a frequency domain specification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
This article presents an open-source tool for the automatic design of reliable finite impulse response (FIR) filters, targeting FPGAs. It shows that user intervention can be limited to a very small number of relevant input parameters: a high-level frequency-domain specification, and input/output formats. All the other design parameters are computed automatically, using novel approaches to filter coefficient quantization and direct-form architecture implementation. Our tool guarantees a priori that the resulting architecture respects the specification while attempting to minimize its cost. Our approach is evaluated on a range of examples and shown to produce designs that are very competitive with the state of the art, with very little design effort.
autofir.pdf (287.17 Ko) Télécharger le fichier
hal-01308377 , version 1 (27-04-2016)
hal-01308377 , version 2 (12-05-2017)
  • HAL Id : hal-01308377 , version 2
Silviu-Ioan Filip, Matei Istoan, Florent de Dinechin, Nicolas Brisebarre. Automatic generation of hardware FIR filters from a frequency domain specification. 2017. ⟨hal-01308377v2⟩
562 Consultations
844 Téléchargements
