Transparent distributed data management in large scale distributed systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2016
In this chapter, we deal with sharing resources transparency in large distributed systems. By using the Data Handover (DHO), together with a peer-to-peer system we provide an easy-to-use architecture to claim resources in dynamic environments: data resources are distributed over a set of peers that may appear and disappear. By means of DHO functions, users request the mapping of data into local memory (for reading or writing) without prior knowledge neither of the location of that data nor of the underlying structure nor of the mobility of peers. This abstraction level is ensured by three managers that interact within our three level architecture. Two algorithms, Exclusive Locks with Mobile Processes (ELMP) and Read-Write Locks with Mobile Processes (RW-LMP), are introduced on the lowest level of the architecture. They ensure data access consistency despite the dynamicity of the environment. Both algorithms satisfy Safety and Liveness properties. Experimental studies show good performance as well as the stability of our approach.
chapter.pdf (469.4 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
hal-01308989 , version 1 (28-04-2016)
  • HAL Id : hal-01308989 , version 1
Soumeya Leila Hernane, Jens Gustedt. Transparent distributed data management in large scale distributed systems. Pervasive Computing, Academic Press, pp.153-194, 2016, 978-0-12-803663-1. ⟨hal-01308989⟩
135 Consultations
141 Téléchargements
